| Subject: 2007 Jeep Wrangler X (JK) 2 doors Automatic Mon Jun 02, 2008 2:20 pm | |
| Sale Price: $23,995.00 With Only 6118 Miles!!2007 Jeep Wrangler 2 door X Modelhttps://s59.photobucket.com/albums/g302/Ticothejeepman/?action=view¤t=4cb43706.pbw Vin# 1J4FA24107L226399 Carfax5 new Nitto Extreme tires and 5 Pro-comp extreme wheels, 3.5” lift and shocks.Exterior Color: Jeep Rescue Green Clear coat/Black Soft TopInterior Color: Dark Slate Gray/Med Slate Gray Remainder of the factory Warranty: | Basic: 36 Months/36000 Miles Corrosion: 60 Months/100000 Miles Roadside Assistance: 36 Months/36000 Miles |
- RDS audio system with AM/FM and CD player CD player reads MP3
- Six speaker(s)
- Fixed mast antenna
- Manual soft-top convertible roof
- Vinyl seat upholstery with additional vinyl
- Bucket driver and passenger seat
- Two one-piece bench front facing removable rear seats with zero adjustments tip/tumble
- Plastic steering wheel with tilt adjustment
- Power steering
- Front seats and rear seats cup holders fixed
- Ventilation system
- Driver and passenger externally adjustable black door mirrors
- Tinted glass on cabin, rear and side
- Front and rear steel wheels with 16 inch rim diam and 7.0 inch rim width
- Wheel opening moldings
- Black front and rear bumpers
- Front and rear all terrain tires with 225 mm tire width, 75% tire profile, S tire rating and black sidewall
- Four-wheel ABS
- Four disc brakes including two ventilated discs
- Immobilizer
- Electronic traction control via ABS & engine management
- Complex surface lens halogen bulb headlights
- Driver and passenger front airbag with multi-stage deployment
- Two height adjustable head restraints on front seats, two head restraints on rear seats
- Height adjustable 3-point reel front seat belts on driver seat and passenger seat
- 3-point reel rear seat belts on driver side and passenger side
- Windshield wipers with variable intermittent wipe
- 3,778 cc 3.8 liters V 6 front engine with 96.0 mm bore, 87.0 mm stroke, 9.6 compression ratio, overhead valve and two valves per cylinder engine code
- Multi-point injection fuel system
- Unleaded fuel 87
- Power: 151 kW , 202 HP SAE @ 5,200 rpm; 237 ft lb , 321 Nm @ 4,000 rpm
- Fuel economy
- Beam front and rear suspension rigid with stabilizer bar and coil springs
- Automatic 4 speed transmission
- 4-wheel drive
- Electronic traction control via ABS & Engine Management
External dimensions: overall length (mm/in): 3881/152.8, overall width (mm/in): 1872/73.7, overall height (mm/in): 1801/70.9, wheelbase (mm/in): 2423/95.4, front track (mm/in): 1572/61.9, rear track (mm/in): 1572/61.9, curb to curb turning circle (mm/ft): 10640/34.9
Internal Dimensions: front headroom (mm/in): 1049/NA, rear headroom (mm/in): 1024/NA, front leg room (mm/in): 1041/H, rear leg room (mm/in): 904/M, front shoulder room (mm/in): 1417/NA, rear shoulder room (mm/in): 1565/NA, interior volume (liters/cu ft): 2914/102.9Who you gone to call? | |
| Subject: Re: 2007 Jeep Wrangler X (JK) 2 doors Automatic Mon Jun 02, 2008 10:47 pm | |
| I think Ive seen that mug shot on americas most wanted awhile back. | |
| Subject: Re: 2007 Jeep Wrangler X (JK) 2 doors Automatic Tue Jun 03, 2008 12:00 pm | |
| For $10 bucks! hahahaha, ain't worth a lick. | |
| Subject: Re: 2007 Jeep Wrangler X (JK) 2 doors Automatic | |
