clark687 Locker/Locker
Number of posts : 120 Age : 34 Localisation : Bel Air, Maryland Emploi : CNC Machinist Registration date : 2008-08-13
| Subject: ANNOYING SQUEAKING NOISE Thu Sep 04, 2008 5:28 pm | |
| hey im getting a real annoying squiking noise in the front when i starter up. then it willl fade out. after a while.
i replaced a wheel in the motor wasnt it. put a new distrubuter cap on. new alternater well that was cracked. i have a feeling its the distrubuter caps rod in it what yall think. | |
| Subject: Re: ANNOYING SQUEAKING NOISE Thu Sep 04, 2008 6:20 pm | |
| the easiest way to detect a noise is to open the hood and start it up and go ot the engine and listen. A stethoscope will help or a wooden dowel held up to your ear. There are lots of things that can squeek in the engine departemnt. Is your belt adjusted correctly? | |
| Subject: Re: ANNOYING SQUEAKING NOISE Thu Sep 04, 2008 6:46 pm | |
| the tensoner pulley us usually the cause. | |
| Subject: Re: ANNOYING SQUEAKING NOISE Thu Sep 04, 2008 9:07 pm | |
| its a jeep, live with it. | |
| Subject: Re: ANNOYING SQUEAKING NOISE Thu Sep 04, 2008 10:35 pm | |
| ooo i have lived with havin the noise just making shoe noth sious could appen like be in pa and the squakyy nise deiceds to be grinding fireyy noise | |
| Subject: Re: ANNOYING SQUEAKING NOISE Fri Sep 05, 2008 2:01 am | |
| so why not replace the belt and keep the old one as a spare? | |
| Subject: Re: ANNOYING SQUEAKING NOISE Fri Sep 05, 2008 8:06 am | |
| just fixed the same type of noise on a 4cyl tj for a friend two weeks ago. it was the fixed bearring on the pass. side of the block. you can press out the bearing and purchase it for $11 and press it back in, or buy the whole unit for $30. when I say press i did it with a hammer and large socket. to find out which bearring is making the noise hit them with wd40 one at a time and see if the noise queits down. if it does you have found the bad bearring. by the you really need to check your typing. I used to think i had the worst, but your starting to make me look like a teacher. | |
| Subject: Re: ANNOYING SQUEAKING NOISE | |
