| 4x4 light | |
clark687 Locker/Locker
Number of posts : 120 Age : 34 Localisation : Bel Air, Maryland Emploi : CNC Machinist Registration date : 2008-08-13
| Subject: 4x4 light Sat Sep 06, 2008 1:12 am | |
| what causes the light that shows if u are engaged in 4x4 h or l. if i pull the stick up no light comes on. soo is that a bad thing if u pull the stick up and your 4x4 light doesnt come on. | |
| Subject: Re: 4x4 light Sat Sep 06, 2008 1:41 am | |
| Subject: Re: 4x4 light Sat Sep 06, 2008 9:53 am | |
| Subject: Re: 4x4 light Sat Sep 06, 2008 10:16 am | |
| Hmmm, been awhile since stock axles but in the YJ I think there was a wire that went down to the front axle that would trigger the light. TJ I'm not sure. | |
| Subject: Re: 4x4 light Sat Sep 06, 2008 10:27 am | |
| NOt sure which heep model this is but looks newer. they mention a 4x4 switch on the tcase. read through the link and it may save you some headache. http://www.jeephobby.com/repairs/4x4_indicator_lamp/how_to_fix_a_broken_4x4_indicator_lamp.php | |
| Subject: Re: 4x4 light Sat Sep 06, 2008 12:02 pm | |
| mine hasn't worked for a while. | |
| Subject: Re: 4x4 light Mon Sep 08, 2008 2:42 pm | |
| The light is worthless. I covered mine years ago to mount my XM radio. Its just a light that in the TJ I believe works off a hookup on the T-case | |
| Subject: Re: 4x4 light Mon Sep 08, 2008 4:54 pm | |
- The light is worthless. I covered mine years ago to mount my XM radio. Its just a light that in the TJ I believe works off a hookup on the T-case
true | |
| Subject: Re: 4x4 light Mon Sep 08, 2008 9:27 pm | |
true thanks Matt | |
| Subject: Re: 4x4 light | |
| 4x4 light | |
