| Stupid 35 | |
magnadyne Open/Locker
Number of posts : 40 Age : 44 Localisation : Bedford, PA Registration date : 2008-02-25
| Subject: Stupid 35 Sun Nov 09, 2008 5:31 pm | |
| Sorry I haven't been on the trails in a while. My jeep has been in the state of constant break down, and I have been slowly rebuilding and improving for months now. I am currently working on the rear end for the second time this year, and it has got me thinking about swapping it with something I do not have to babysit or worry about.... (at least as much). My lift required new arm & shock mounts so even a TJ D44 will not bolt right up any more, so if I am going to replace the axle I might as well make it worth my time. I am hoping to find something that fits the following: 1) Near stock width. However, I am willing to go up to 65". I plan on upgrading the front to (most likely) a 44. 2) Lots of aftermarket options easy to find parts. 3) Room to grow. Meaning I don't want to have to swap everything out again when I get larger tires. (37's) Right now I am leaning towards the 8.8 I know many of you have been down this road before, and was wondering your thoughts now that you have that 20/20 vision. | |
| Subject: Re: Stupid 35 Sun Nov 09, 2008 6:09 pm | |
| You need to decide if you plan on keeping it street legal or not. if the width allows the tire to stick out past the flares then you will get a ticket for it in maryland and in PA. I've seen a lot of people do an 8.8 swap, quick, easy and strong. And most important a little narrower than stock allowing it to sty legal. | |
| Subject: Re: Stupid 35 Sun Nov 09, 2008 6:22 pm | |
| Good point. I do want to stay street legal, my 35 are already sticking out past my 7" flares. I figure if something like a 9" that is available in 65" width is the best option I would get wheels with different backspacing to compensate. In this case I would have to get new wheels anyway because of the different bolt pattern. | |
| Subject: Re: Stupid 35 Sun Nov 09, 2008 6:29 pm | |
| http://www.rc4x4.org/rcforum/index.php/topic,3162.0.html | |
| Subject: Re: Stupid 35 Sun Nov 09, 2008 6:40 pm | |
| Nice! I will give him a call.
Thanks! | |
| Subject: Re: Stupid 35 Sun Nov 09, 2008 6:46 pm | |
| I have an 8.8 with 3.73 gears for sale. | |
| Subject: Re: Stupid 35 Sun Nov 09, 2008 10:10 pm | |
- I have an 8.8 with 3.73 gears for sale.
How much? I also have a buddy at scrap yard looking into things. I am running 4.56 gears and a locker. Keeping the axle cheap would be nice because I am going to have to replace the guts anyway. | |
| Subject: Re: Stupid 35 Sun Nov 09, 2008 10:33 pm | |
| Right now I have $400 tied up in it with being set up for a 4 link suspension. | |
| Subject: Re: Stupid 35 Sun Nov 23, 2008 6:00 pm | |
| Went to the junk yard today to what they have. I ran across a late 70's F150 with hp D44 front and 9" rear. It will be about as wide as I want to go, but I like the idea of not having to chop. I will try to tame the width a bit with more back spacing. They have 8.8's galore. and many 9". Not too much on the D44 fronts though. I did run across a 9" that had some sort of spring mechanism in the diff. My guess is a limited slip of some sort? There wasn't much left of the truck to tell what it was though. They also had 1 early Bronco, and a CJ. I need to go back there, so if anyone is looking for something, let me know I can see if they have it. | |
| Subject: Re: Stupid 35 Sun Nov 23, 2008 6:25 pm | |
| Subject: Re: Stupid 35 Sun Nov 23, 2008 7:55 pm | |
| It's a small one near East Freedom, PA. (Not sure of the name of hand) A coworker works there part time and is good friends with the owner. They have helped me out with parts before. Good people. | |
| Subject: Re: Stupid 35 | |
| Stupid 35 | |
