| will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? | |
| Subject: will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? Tue Nov 25, 2008 8:54 am | |
| CURRIOUS. I WAS LOOKING AT RIMS FROM SOME H2'S WITH TIRES ON THEM CAUSE IT IS THE SAME TIRE SIZE AS MY TRUCK, IT WOULD BE A GREAT BONUS IF THE RIMS FIT MY 1986 F350 BUGGY AXLES OR EVEN MY 03 DODGE RAM AXLES. (NOT SURE BUT I THINK MY BUGGY AND DODGE ARE THE SAME PATTERN) ?? CAN ANYONE SHED SOME LIGHT ON THIS | |
| Subject: Re: will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? Tue Nov 25, 2008 9:11 am | |
| I'm 99% sure they fit the d60, because people talk about using them because of the huge amount of back spacing. Also i know for a fact that they bolt up to the older dodge axels because grasons brother has set on his late 90's dodge. | |
| Subject: Re: will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? Tue Nov 25, 2008 6:14 pm | |
| Subject: Re: will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? Tue Nov 25, 2008 8:20 pm | |
| The H2 rims I have had to be "clearanced" by removing the small ridge in the center opening to allow room for the bigger ford hub. The backspacing is like 5 1/2". Kat is going to aquire my set, you can probably try them on to see if they fit.. I'm hoping to get the wheels and axle to her in the next 2 weeks. | |
| Subject: Re: will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? Tue Nov 25, 2008 11:11 pm | |
| i think i am going to get a set of h2 rims and wheels since it will fit both, there is a set on craigslist for 500.00 tires and rims. i have to save money first though. with x-mass coming there is no extra money | |
| Subject: Re: will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? Tue Nov 25, 2008 11:27 pm | |
| just the rims are going for about $300 | |
CamoK5 Locker/Locker
| Subject: Re: will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? Wed Nov 26, 2008 8:04 am | |
| As long as the Ford or Dodge axles are 8x6.5 they will work. I'm not sure what year but ford changed to 8x170mm, not sure about Dodge. | |
| Subject: Re: will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? Wed Nov 26, 2008 11:42 am | |
| They will fit the newer dodges too. | |
| Subject: Re: will an 8 lug 03 hummer H2 rim fit my 1986 ford f350 8x6.5 ? | |
