 Tie rod ends or heim joints
View previous topic View next topic Go down
CamoK5
Number of posts: 153
Registration date: 2007-01-20
PostSubject: Tie rod ends or heim joints   Sun Dec 14, 2008 7:51 pm
Well I picked up my higher steer crossover this morning it is complete except for rod ends. Should I go with GM rod ends or Heim joints ?
Mark
UPNOVER
Number of posts: 856
Registration date: 2007-01-19
PostSubject: Re: Tie rod ends or heim joints   Sun Dec 14, 2008 7:58 pm
If you are not driving it on the road go with the heims........
lt.dan
Number of posts: 89
Registration date: 2008-11-12
PostSubject: Re: Tie rod ends or heim joints   Sun Dec 14, 2008 8:00 pm
i prefer tie rod ends, they last longer, and are able to be lubricated, heims tend to wear fast, and are expensive to replace, i use 3/4 ton chevy ends on my jeep.
UPNOVER
PostSubject: Re: Tie rod ends or heim joints   Sun Dec 14, 2008 8:08 pm
Last longer???? Maybe under normal conditions. I would think the heim would last longer due to strength..
UPNOVER
PostSubject: Re: Tie rod ends or heim joints   Sun Dec 14, 2008 8:10 pm
I might actually have a couple from the buggy.. Once the game is over I will check the trailer box...and pm..
Number of posts: 2550
PostSubject: Re: Tie rod ends or heim joints   Sun Dec 14, 2008 8:21 pm
I guess it depends on what you like to run. How often you clean and maintenance your rig. I went with tie rod ends for my high steer on my Dana 44 and also with the toyota.
Number of posts: 3649
PostSubject: Re: Tie rod ends or heim joints   Sun Dec 14, 2008 9:39 pm
I also run the chevy tie rod ends and have beat the snot out of them without issues. The front axle was built by Full Circle Performance and I respect their decisions. I bought high steer arms for the CJ project and will be using chevy tie rod ends on that as well. Only one of each needed for a spare for both jeeps. If you end up needing to replace one because of breakage where will you get a spare heim joint? Tie rod ends can be picked up at just about any auto parts store.
[/url]http://www.facebook.com/home.php#!/profile.php?v=info&ref=profile&id=100000213229958[url]
UPNOVER
PostSubject: Re: Tie rod ends or heim joints   Sun Dec 14, 2008 9:54 pm
I always thought the heims were stonger.. ?????
I searched Pirate and didnt really find anything with specs....
This is definitely food for thought........
jealos-z
Number of posts: 604
Emploi: Mechanic
Registration date: 2007-09-17
PostSubject: Re: Tie rod ends or heim joints   Sun Dec 14, 2008 10:09 pm
I have ran my heims for 3yrs and never had a problem I love them on the street to very responsive little wd40 once in awhile . Mine are 3/4in chromoly
92 YJ (TRAIL TESTED)
NO DRAMA OR POLITICS
I GOT MARR " DON'T ASK IT WILL ASK YOU"
lt.dan
Number of posts: 89
PostSubject: Re: Tie rod ends or heim joints   Mon Dec 15, 2008 12:14 am
3/4 ton chevy trucks can go 80k miles on a tierod end that aint gona hapen with heim joints. dfjsksdkfjsd
View previous topic View next topic Back to top
» Essien - Ends 10th Jan - 17:13:30
» Hazard - Midfielder - Ends 16th Jan 15:35:52
» Craig Dawson - Defender - Ends 6 Jan @ 17:54:07
» Thomas Hitzlsperger - midfielder - ends 29 july @ 6:20:04
» Papis Demba Cisse - striker - Ends 18th Jan 17:08:09
