 Rubicon CV shafts
UPNOVER
Number of posts : 856
PostSubject: Rubicon CV shafts   Tue Dec 23, 2008 10:26 am
Sweet!!!!!!!!!!!
http://pirate4x4.com/forum/showthread.php?t=741733
Number of posts : 438
PostSubject: Re: Rubicon CV shafts   Tue Dec 23, 2008 6:37 pm
these are great axles I have been running them for over a year now. Bobby made longfields for the Dana 60 and now the dana 44 they will hold up better than any u joint axle.
PostSubject: Re: Rubicon CV shafts   Tue Dec 23, 2008 10:28 pm
Yeah if they end up making them for a real Dana 44 I will buy them with out question. I'm going to order the ones for the Toyota in the next couple of days.
PostSubject: Re: Rubicon CV shafts   Wed Dec 24, 2008 12:10 am
so where would the weak link be? could do a hub fuse.
PostSubject: Re: Rubicon CV shafts   Wed Dec 24, 2008 12:28 am
Well for the type of wheeling the YJ does it might not be a real weak link. The stock ford hubs are the weak link has is. I do want to upgrade the hubs soon and I was thinking axles but I might hold off for some time. Its a strong front end in stock form. I'm sure Emily will break something once I start wheeling the Toy and it will give me reason to upgrade.
PostSubject: Re: Rubicon CV shafts   Wed Dec 24, 2008 2:04 am
44 shafts are the weak link. stock ones have some crazy neck down. But once you upgrade those it becomes the hubs. cant run hubs with those shafts, have to use unit bearings.
I'm dumb
My dog ate my turtle
Rubicon CV shafts
» Old mine shafts
» GPX 4000 3 piece shafts,shaft lengths.{detectors}
» Kawasaki Teryx on the Rubicon Trail
» Otto fibreglass shafts
» Transmission with Side input and output shafts?
