| rear d60 disk brakes. | |
| Subject: rear d60 disk brakes. Thu Feb 05, 2009 4:53 pm | |
| For those who swaped disk brakes on rear 60's, what parts did you use. | |
| Subject: Re: rear d60 disk brakes. Thu Feb 05, 2009 5:19 pm | |
| Ask Bill. I think he still has it sitting around. | |
| Subject: Re: rear d60 disk brakes. Thu Feb 05, 2009 6:24 pm | |
| I bought a kit online for just under $300. It made it simple and didn't have to figure out the exact dimentions to make one etc. You could have the whole rear axle for $500 or so. new disc brakes, new rotors, new calipers, new bearings. 3.55 or so gears, no locker, 31 spline I believe. | |
| Subject: Re: rear d60 disk brakes. Thu Feb 05, 2009 7:09 pm | |
| I would but i already purchased ballistics disc brake brakets So I don't want to waste them. That and I have this axel right in front of me. | |
| Subject: Re: rear d60 disk brakes. Thu Feb 05, 2009 7:24 pm | |
| Bill - I may still grab that 60 off of you. Just in case....... | |
| Subject: Re: rear d60 disk brakes. Thu Feb 05, 2009 7:50 pm | |
| Chevy 3/4" ton K-20 front calipers and rotors. that is what I used on my 14bolt and what the web site said. | |
| Subject: Re: rear d60 disk brakes. Thu Feb 05, 2009 8:23 pm | |
| Thats what they said but after i started looking at the parts online I began to wonder if they would work right Because auto zone had all sorts of screwy part numbers which some were special order. | |
| Subject: Re: rear d60 disk brakes. Thu Feb 05, 2009 11:54 pm | |
| http://www.pirate4x4.com/tech/billavista/14b_disc_brakes/ | |
| Subject: Re: rear d60 disk brakes. Fri Feb 06, 2009 12:10 am | |
| - Mad4Mud wrote:
- Bill - I may still grab that 60 off of you. Just in case.......
just in case I was RIGHT and you should have swapped out that low pinion 9" when you had the chance? | |
| Subject: Re: rear d60 disk brakes. | |
