| Fuel cell questions | |
| Subject: Fuel cell questions Tue Feb 03, 2009 10:43 am | |
| The stock fuel tank has been removed, new steel tank if anyone is interested. I will be using a fuel cell in the bed of the CJ. With the 454 I'm thinking I'd better go with about 12-15 gallons. I also need fuel lines to match. Any recommendations? | |
| Subject: Re: Fuel cell questions Tue Feb 03, 2009 7:26 pm | |
| I would do 15 gallons at least if you plan on doing any type of riding with it. Also keep in mind the last couple of gallons are useless when you get off camber. i.e. a 15 gallon tank is only 10 to 12 gallons on a small hill. | |
| Subject: Re: Fuel cell questions Tue Feb 03, 2009 7:35 pm | |
| Bill are you goin to have a top on jeep cuz my buddy did that and took it out cuz of the smell and he had a good fuel cell to wasn't a cheap one just a thought. I agree with joe tho 15 for sureand run steel braided lines with an fittings | |
| Subject: Re: Fuel cell questions Tue Feb 03, 2009 8:22 pm | |
| It will have a top. Only plan on having it closed when in mud, which if I build this right wont take long to get through. I could do the divider between the rear and front compartment to seal it back there. there will be no rear passenger seat. Didn't think about it being off camber and last couple gallons useless, good call. Should I run the steel braided lines all the way to the carb? | |
| Subject: Re: Fuel cell questions Tue Feb 03, 2009 8:24 pm | |
| i would think the fuel cell would be completely sealed and the vent could run outside the cab? | |
| Subject: Re: Fuel cell questions Tue Feb 03, 2009 9:57 pm | |
| You should be able to vet it outside no prob. Keep in mind those fitting are exspensive i priced them out at a couple hundred to run them in the zj. I ended up going with $10 in rubber hose and connected it to the old fuel lines. So if you don't mind spending the extra cash go for it. Will give the engine compartment more bling. | |
| Subject: Re: Fuel cell questions Tue Feb 03, 2009 11:09 pm | |
| OUCH! I work better with rubber now that you mention it. | |
| Subject: Re: Fuel cell questions Tue Feb 03, 2009 11:48 pm | |
| My Buddy ran an to front and still had smell let me tell you he is a very anal person does stuf rite ... and yes those fittings are not cheap 20 a peice but they are nice and dont leak | |
| Subject: Re: Fuel cell questions Wed Feb 04, 2009 12:38 am | |
| When I use to have a hard top on mine it only smelled when I filled it up.
Since you have a carb you don't have the p.s.i. that a EFI would so rubber hose and hose clamps will work fine. | |
| Subject: Re: Fuel cell questions Thu Feb 05, 2009 12:21 am | |
| True Matt I 4got Bill had a carb | |
| Subject: Re: Fuel cell questions Thu Feb 05, 2009 9:43 pm | |
| http://pirate4x4.com/tech/billavista/Plumbing/
I saw this and thought that maybe there is some info that might help you. | |
| Subject: Re: Fuel cell questions Mon May 25, 2009 11:50 am | |
| Just about ready to order the fuel cell now. I'll be getting the RCI 2161A which I believe is the same one Joe bought. just wondering if I need fittings on the top of the fuel cell or will the rubber hose attach directly to the top of the cell. ALso what size hose is needed? | |
| Subject: Re: Fuel cell questions Mon May 25, 2009 9:45 pm | |
| you will need fittings to convert from -8an to a hose barb to go to carb. a -8an cap for the return (I don't think you need a return), and -8an to barb to put a hose on for vent. best but is to call when you're ordering, they were very helpfull when my brother ordered all his stuff. | |
| Subject: Re: Fuel cell questions Tue May 26, 2009 7:41 am | |
| thanks, I figured there would be something. | |
| Subject: Re: Fuel cell questions Tue May 26, 2009 10:32 am | |
| Found a Billvista link on fuel cell tech. http://www.pirate4x4.com/tech/billavista/Fuel_Cell/ | |
| Subject: Re: Fuel cell questions Tue May 26, 2009 6:49 pm | |
| ordered my female -8 an fittings today, 1 for fuel, 1 for vent, 1 cap. also ordered a fuel pressure guage with in line adaptor, and a new fuel filter. Problem I was having was going from the -8 size which is 1/2" down to 5/16 at the fuel pump and 3/8 line to the carb. I think I have enough parts to figure it out now once it comes in. | |
| Subject: Re: Fuel cell questions Thu May 28, 2009 8:24 pm | |
| Damn! Summit is quick. just got my stuff in from UPS and it all fits. | |
| Subject: Re: Fuel cell questions | |
