 rear d60 disk brakes.
PostSubject: rear d60 disk brakes.   Thu Feb 05, 2009 4:53 pm
For those who swaped disk brakes on rear 60's, what parts did you use.
MARR step up or step out
PostSubject: Re: rear d60 disk brakes.   Thu Feb 05, 2009 5:19 pm
Ask Bill. I think he still has it sitting around.
PostSubject: Re: rear d60 disk brakes.   Thu Feb 05, 2009 6:24 pm
I bought a kit online for just under $300. It made it simple and didn't have to figure out the exact dimentions to make one etc. You could have the whole rear axle for $500 or so. new disc brakes, new rotors, new calipers, new bearings. 3.55 or so gears, no locker, 31 spline I believe.
PostSubject: Re: rear d60 disk brakes.   Thu Feb 05, 2009 7:09 pm
I would but i already purchased ballistics disc brake brakets So I don't want to waste them. That and I have this axel right in front of me.
MYYJROX
Number of posts : 738
PostSubject: Re: rear d60 disk brakes.   Thu Feb 05, 2009 7:24 pm
Bill - I may still grab that 60 off of you. Just in case.......
93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage
02 Tahoe with Rancho lift
02 Ram Air Trans Am
PostSubject: Re: rear d60 disk brakes.   Thu Feb 05, 2009 7:50 pm
Chevy 3/4" ton K-20 front calipers and rotors. that is what I used on my 14bolt and what the web site said.
I'm dumb
My dog ate my turtle
PostSubject: Re: rear d60 disk brakes.   Thu Feb 05, 2009 8:23 pm
Thats what they said but after i started looking at the parts online I began to wonder if they would work right Because auto zone had all sorts of screwy part numbers which some were special order.
PostSubject: Re: rear d60 disk brakes.   Thu Feb 05, 2009 11:54 pm
http://www.pirate4x4.com/tech/billavista/14b_disc_brakes/
I'm dumb
PostSubject: Re: rear d60 disk brakes.   Fri Feb 06, 2009 12:10 am
just in case I was RIGHT and you should have swapped out that low pinion 9" when you had the chance? jocolor
MYYJROX
PostSubject: Re: rear d60 disk brakes.   Fri Feb 06, 2009 11:48 am
Exclamation Nothing wrong with my 9"...it is the adapters I'm concerned about. If I have any problem with them then I'll have to convert to full float....there is no other option there if I keep the 9. That will mean changing my axle shafts (need 35 slpine instead of 31) and replacing the locker and the spare 3rd I have wouldn't be too helpful (except for the gears). It may just be cost effective to put the 60 in instead. I'll have to wait and see how it goes.
02 Ram Air Trans Am
» Rhino Rear Brake?????
» Rhino Rear Brake AWFUL Noise -- Normal??
» Will Hydraulic brakes from ATVs and pit bikes work on a tractor?
» rhino is pissing me off
» How do you set up after market brakes?
