 c-6 tranny rebuild
PostSubject: c-6 tranny rebuild   Sat May 02, 2009 8:16 am
i had no problems last time out with my tranny overheating at all. but i think i might of run the pump dry on hells hole. it wines when you rev it up now and in my opinion it does slip when it gets hotter. i have a spare c-6 tranny and i am going to perform a rebuild on it myself. it is only 3 gears (no overdrive) and my older brother has rebuilt th350 before. so he can give me some insight. maybee if anyone can find a c-6 transmission rebuild video somewhere you can post a link. thank you. i have to fix my buggy damage from hells hole first, then i can check the tranny i have in it now to see the extent of the damage. I WOULD THINK IT COULD BE JUST THE PUMP GOING UP THAT IS MAKING THE WINING SOUND. BUT I HAVE TO PULL THE TRANNY TO GET TO THAT ANYWAY. any advice or links would help
DONT FOLLOW ME!!
PostSubject: Re: c-6 tranny rebuild   Sat May 02, 2009 11:37 am
Ford Transmissions are notorious for whinning. Its the nature of the beast and most of the time its due to valves getting worn out. I personally have never torn one apart but have owned a couple of fords that have done what your talking about.
PostSubject: Re: c-6 tranny rebuild   Sat May 02, 2009 11:44 am
Von there is a Ton of info on google. I did a search for "c 6 transmission rebuild" there is pages of info but the first link looked good.
http://www.4wheeloffroad.com/techarticles/ford_c6_automatic_transmission_rebuild/index.html
PostSubject: Re: c-6 tranny rebuild   Sat May 02, 2009 11:48 am
first i am going to change my filter and re-assemble. then i will go from there.it will be awhile though, i don't have allot of spare time and i have to fix my rear drive shaft and all first. i am not going to pull it unless i have to
DONT FOLLOW ME!!
PostSubject: Re: c-6 tranny rebuild   Sat May 02, 2009 2:08 pm
sounds like you have good plan. I wouldn't pull it either unless you have to.
PostSubject: Re: c-6 tranny rebuild   Sun May 03, 2009 10:39 am
do you think this is worth me acquiring for a spare just in case something is wrong with my tranny. it also has my same t.c on ithttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=140317897131&sspagename=STRK%3AMEWAX%3AIT&viewitem=
it doesn't seem like i can go wrong with it, BUT IT IS A 2 HOUR TRIP ONE WAY TO GET IT
DONT FOLLOW ME!!
PostSubject: Re: c-6 tranny rebuild   Tue May 05, 2009 9:05 pm
i bought the c-6 tranny with a 205 t.c on it for $45.00 . (what a deal) they said the tranny was rebuilt last year. we will see 9 and it came with the torque converter
DONT FOLLOW ME!!
PostSubject: Re: c-6 tranny rebuild   Wed May 06, 2009 9:47 pm
i am going to get it tommorrow...........BILL, it is somewhat near you isn't it. in smithsburg md 21783 up rt. 70
DONT FOLLOW ME!!
PostSubject: Re: c-6 tranny rebuild   Sat May 09, 2009 8:58 am
well i picked it up. every time i move one of these 205 around i remember how heavy the bastard is 2 . and this one had a c-6 on it. good thing the guy had a forklift to load it for me. i took the transfer case off to make it easier to move at home. the tranny fluid in this c-6 looks crystal clear and bright red. he said that it ran fine and it was rebuilt over a year ago. i am going to check the fluid/filter in mine and make the decision at that point if i am just going to change the whole thing. it should not be that hard to pull the whole tranny out. i will take pics and post them
DONT FOLLOW ME!!
PostSubject: Re: c-6 tranny rebuild   Sat May 09, 2009 11:53 am
sweet deal! yeah smithsburg is about 30 min north of me
If you have an extra Ford 205 lying around I may be interested in one.
PostSubject: Re: c-6 tranny rebuild   Sat May 09, 2009 7:13 pm
but offcourse i have an extra,just let me know. i will hold onto it. hope you feel better soon
DONT FOLLOW ME!!
PostSubject: Re: c-6 tranny rebuild   Sat May 09, 2009 8:24 pm
thanks Von. I may end up going with a built Ford motor instead of building the Chevy 454. benefit is i can run a ford (drivers drop) 205 that can handle the HP and won't require any adaptors. It will be awhile though before I have to make that decision.
PostSubject: Re: c-6 tranny rebuild   Thu May 14, 2009 9:07 am
here is an update, i removed my trans and transfer case and installed the other tranny, everything seemed to line up great. but i had a 1/16 gap at the bottom of the tranny and engine, so as i tightened the bolts up the gap was lessening, so i was like mbn . until the tranny housing cracked asdyuysigidfdjbisd . i was disgusted and went inside to go to bed....i have a np435 in my garage, i was thinking about putting in it. that would give me a crawl ratio of 52 with the 205 behind it, or a ratio of 72 with the np208 that is on that now. in either case i would have to put a clutch pedal in and a new clutch assembly and change the bell housing on it from a small block to a big block ford.(much cheaper then an atlas) but there would be no more overheating or tranny slippage issues to deal with. IDEAS AND INPUT PLEASE??
DONT FOLLOW ME!!
PostSubject: Re: c-6 tranny rebuild   Thu May 14, 2009 2:51 pm
well i made a whole bunch of calls today and came up short on finding a stock 460 bell housing to match up to a np435 or a T-18 WHICH I UNDERSTAND IS THE SAME BOLT UP
DONT FOLLOW ME!!
c-6 tranny rebuild
» what kinda oil do you use in your tranny?
» tranny question
» Old Yamaha scooter rebuild
» RZR Rebuild
» Fox Shocks Rebuild/Upgrade
