| Jeep won't start | |
 Number of posts : 738 Age : 46 Registration date : 2007-01-19
 | Subject: Jeep won't start Sat May 02, 2009 8:55 pm | |
| Bill sent me some info on what to check on the Jeep to see why it won't start but I haven't done anything yet other than check the fault codes and I got an 11. Jon was talking about the magnetic uptake in the distributor going bad in his and that being a possible problem on mine. If that is the problem, wouldn't I get an error code 54 (Code 54 - Distributor sync pickup)?? _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 Number of posts : 1875 Age : 38 Localisation : Towson, MD Registration date : 2007-01-20
 | Subject: Re: Jeep won't start Sun May 03, 2009 1:12 am | |
| crank position sensor _________________ "A yahoo made dangerous with power tools"  MARR step up or step out Who me? I didn't do it and you can't prove it. Also by chance do you have a lighter? |
 Number of posts : 3671 Age : 50 Localisation : Knoxville, MD Registration date : 2007-01-20
 | Subject: Re: Jeep won't start Sun May 03, 2009 8:55 am | |
 | Subject: Re: Jeep won't start Sun May 03, 2009 1:48 pm | |
| if a zj 4.0 CPS is the same as a YJ 4.0 CPS I have one you can try out to see if it works. _________________ "A yahoo made dangerous with power tools"  MARR step up or step out Who me? I didn't do it and you can't prove it. Also by chance do you have a lighter? |
 | Subject: Re: Jeep won't start Sun May 03, 2009 2:05 pm | |
| hey they both have the same part numbers, so they are interchangeable. Let me know if you want to swing by and grab that and the tube. _________________ "A yahoo made dangerous with power tools"  MARR step up or step out Who me? I didn't do it and you can't prove it. Also by chance do you have a lighter? |
 | Subject: Re: Jeep won't start Mon May 04, 2009 11:33 am | |
| Thanks Joe, that would be great. I'll try that first and if that doesn't work then start trying other things. I'll try to meet up with you one night this week. I'll bring your decals over too.
FYI - My dad is used to having the real factory service manuals when diagnosing problems so I just picked up a 1993 Wrangler set from eBay for $25 if anybody needs to use them. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: Jeep won't start Thu May 07, 2009 2:44 pm | |
- hey they both have the same part numbers, so they are interchangeable. Let me know if you want to swing by and grab that and the tube.
What time are you going to be home tonight? _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: Jeep won't start Thu May 07, 2009 6:38 pm | |
| i'm home now but the parts are still at the shop. _________________ "A yahoo made dangerous with power tools"  MARR step up or step out Who me? I didn't do it and you can't prove it. Also by chance do you have a lighter? |
 | Subject: Re: Jeep won't start Wed May 13, 2009 5:51 pm | |
| The new CPS came in today and I installed it. The Jeep started right up. Hopefully that is the end of that problem. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: Jeep won't start Wed May 13, 2009 6:38 pm | |
 Number of posts : 972 Age : 44 Localisation : Perry Hall, MD Registration date : 2007-01-22
 | Subject: Re: Jeep won't start Thu May 14, 2009 8:29 am | |
| cool beans  i am glad it was able to make it out of the trails on its own at big dogs _________________ DONT FOLLOW ME!!
 | Subject: Re: Jeep won't start Thu May 14, 2009 10:54 am | |
| Yeah, it would not have been fun trying to get it out of Death Valley. I was lucky it started up again there and didn't die completely until Hell Hole where Jon could pull it back easily.
Now I just have to beat the exhaust pipe out of the way of the front driveshaft and weld the bumper back on and it should be good to go again. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: Jeep won't start  | |
