| June Big Dogs | |
 Number of posts : 1243 Age : 35 Localisation : north harford Registration date : 2007-01-20
 | Subject: Re: June Big Dogs Fri May 29, 2009 9:37 pm | |
| none here either. nester your not bringing the jeep.
so as of now its
Matt +1 bill +1 rob+1 nick+1 chuck+1 ? chris+1 ? joe+1 nester+3 ?
and von and kathy saturday night-sunday 20 people its going be a good time
did i forget anyone. _________________ I'm dumb
My dog ate my turtle
 Number of posts : 502 Age : 40 Localisation : Stillwater,PA Registration date : 2008-04-09
 | Subject: Re: June Big Dogs Fri May 29, 2009 10:09 pm | |
| - Quote :
- Fingers are crossed and I'm bringing Elva in case I need mouth to mouth, ain't none of you dirty fuckers putting your lips on me.
That hurts bill I would give you some air if you went flat.Or we could just jump up and down on you. We are in for the weekend haven't decided yet when we will leave to get there will be there Thursday nite or afternoon some time. What time are people going to be getting there ? Just thinking we need to set tent and stuff up and doing that in dark sucks. _________________ "PROVE IT OR SHUT UP"
Chuck
[/i]92 YJ Full width front D-44 W/ E-lock rear 9in W/spool 39.5 irocs With ROCKY II pet blow up turtle
 | Subject: Re: June Big Dogs Fri May 29, 2009 10:30 pm | |
| I was thinking arround 8 but I am open to anything. I have off but I have to do a little work to the jeep. joe if you want to meet up on the way down just let me know, I didn't meet up with you last time and you didn't show.  _________________ I'm dumb
 Number of posts : 738 Age : 46 Registration date : 2007-01-19
 | Subject: Re: June Big Dogs Fri May 29, 2009 11:06 pm | |
| - jealos-z wrote:
- No seats here sorry, the way it stands now we are 4sure gona be there thurs nite the only thing that could fuk me is Tires Mike at Pitbull says they will be here tues at the latest jeep sits on stands rite now...I hate waiting on sumone else...
Rob - if there is any kind of hang up I have a set of 36" TSLs you can use. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: June Big Dogs Fri May 29, 2009 11:14 pm | |
I know you aren't including me in the dirty fuckers list.  I may be alot of things but a dirty fucker isn't one of them.  I'm sure what you meant to say is if I rescued you it would be a wasted effort because Elva would kill you when you got home. Right Bill?  _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 Number of posts : 2558 Age : 36 Localisation : Ashburn, VA Registration date : 2007-01-19
 | Subject: Re: June Big Dogs Sat May 30, 2009 12:01 am | |
- none here either. nester your not bringing the jeep.
I want to but the cage isn't done with the install and it is halfway apart. That and I also have the not found the axle shaft for it and havent spent the money on the chromo shafts yet. _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 | Subject: Re: June Big Dogs Sat May 30, 2009 12:11 am | |
| I'm a little bummed about not being able to take the jeep but very happy that I get to take the toyota and I can beat on the toyota for a long weekend. I will have to work harder with no locker but I think I might be able to make it work. _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 Number of posts : 1875 Age : 38 Localisation : Towson, MD Registration date : 2007-01-20
 | Subject: Re: June Big Dogs Sat May 30, 2009 1:22 am | |
| well heres the to do list for big dogs for me. If any of you have some free time and fell like tackeling any of the list below please fell free to do so.
1. cut/ weld/ install tie rod 2. install ram mounts and ram 3 install ram skid 4. weld up fron drive shaft 5. fix front bump stops 6. cut redrill track bar bracket 7. Bleed brakes 8. install rear axle breather 9. install fuel breather 10. install electric fan 11. install electric fan wiring 12. rear bump stops 13. limiting straps 14. gear oil 15. fix grease fitting 16. grease fitting protection 17. grease 18. install OBA stuff 19. Pack up jeep _________________ "A yahoo made dangerous with power tools"  MARR step up or step out Who me? I didn't do it and you can't prove it. Also by chance do you have a lighter? |
 Number of posts : 1783 Age : 34 Localisation : Reading, PA Registration date : 2007-02-09
 | Subject: Re: June Big Dogs Sat May 30, 2009 2:39 am | |
| Here's my to do list... 1. Pull apart front shaft and lube it (jeeps are like women keep it lubed and they're happy) 2. Put piece of shit jeep on trailer 3. Count down time till we hit the dirt road towards the cove campround 4. Crack a beer and turn on cuntry music normally starting with good ol' hank jr 5. Throw the tent up and get drunk and smile the rest of the weekend remembering why I deal with the piece of shit Jeep the other ~360 days of the year. don't forget step 6 Wheel the piss out of it and hope it doesn't break The formula hasn't failed me yet and if it does  _________________ '92 YJ 1.5" RE SOA, 2" body, 37" Krawlers, D44 ARB, 8.8 ARB 4.88s, 4:1. Worn out but still gettin' it!
 | Subject: Re: June Big Dogs Sat May 30, 2009 9:18 am | |
| Yeah I guess I will put my list up too.
1. Fix front axle drain plug 2. Load tool box on the toyota with gear. 3. Drag the trailer over to the house and load toyota 4. Load Cooler & camping gear 5. Hitch up and roll out.
If the weather looks nice I will be taking the doors off the toyota. So I might have to add a step in there. _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 Number of posts : 604 Age : 44 Localisation : Bloomsburg PA Emploi : Mechanic Registration date : 2007-09-17
 | Subject: Re: June Big Dogs Sat May 30, 2009 1:44 pm | |
| WOW 1 mount tires 2 put them on jeep 3 cut whatever is in the road out of the road 4 put junk on trailer 5 leave for BEST WHEELING NEWHERE I HOPE........... IT HAS TO BE BETER THAN THE REGISTRATION CRAP _________________ 92 YJ (TRAIL TESTED) NO DRAMA OR POLITICS
I GOT MARR " DON'T ASK IT WILL ASK YOU"
 | Subject: Re: June Big Dogs Sat May 30, 2009 6:20 pm | |
| My list is done 1 installed rock lights 2 put new center pins in rear leafs ( now it goes straight) 3 Jeep is loaded Well I guess im not done 1 clean jeep 2 load stuff in truck 3 help chris with monster s-10 (lights) 4 change joints in spare drive shaft 5 Do reg 6 get new wheels on tow rig _________________ "PROVE IT OR SHUT UP"
Chuck
 | Subject: Re: June Big Dogs Sat May 30, 2009 7:06 pm | |
| Fucking rock lights? I know that I would need something last minute. _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 Number of posts : 972 Age : 44 Localisation : Perry Hall, MD Registration date : 2007-01-22
 | Subject: Re: June Big Dogs Sat May 30, 2009 9:40 pm | |
| here is my list. 1-pack clothes 2-pack beer 3-pack tent 4-hop in truck saterday afternoon to leave WOW, ITS KINDA NICE NOT HAVING TO WORRY ABOUT ANYTHING THIS TIME  _________________ DONT FOLLOW ME!!
 Number of posts : 3671 Age : 50 Localisation : Knoxville, MD Registration date : 2007-01-20
 | Subject: Re: June Big Dogs Sat May 30, 2009 9:41 pm | |
| gave er a once over and only thing I have to do is load er up and go. Of course since I'm +1 on this trip there is a lot of CRAP that i have to bring with me you know like pillows and blankets and tea and stuff like that. |
 | Subject: Re: June Big Dogs Sat May 30, 2009 9:43 pm | |
| - thinga'ma'rig wrote:
- here is my list.
You can erase #2 - it's on me but you can replace it with "bring dum dum to get us there"  _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: June Big Dogs Sun May 31, 2009 2:08 pm | |
| REG DONE Now  In that order _________________ "PROVE IT OR SHUT UP"
Chuck
adrenaline325 Locker/Locker
 Number of posts : 103 Age : 48 Localisation : laurel md Emploi : piccotek Registration date : 2007-09-22
 | Subject: Sat night- Sunday? Mon Jun 01, 2009 12:10 am | |
| I am thinking about coming out this weekend - seems like there will be several rigs running Sunday -
I could not get there until about 9 or 9:30 on Saturday night, and would want to get in some night riding Saturday night and a few trails on Sunday. I can have 1 or if requested (and so install rear seat) 3 spare seats of anyone is looking for a spare seat on Sunday only...
All the same I would like to be on the trails on Sunday until around 3 pm and would like to do some night runs on Saturday night if at all possible - I haven't done that before.
How are things shaping up for Sunday? Do we still have several riders heading out for just Saturday night and Sunday?
PS this would also mean I could bring any parts that are needed for Sat night repairs - at least anything that is in stock at the adrenaline shop... |
 | Subject: Re: June Big Dogs Mon Jun 01, 2009 12:40 am | |
| - adrenaline325 wrote:
- How are things shaping up for Sunday? Do we still have several riders heading out for just Saturday night and Sunday?
I will definitely be there Saturday night for a night run (my favorite) and will be running Sunday. Von will be with me but is not bringing either of his rigs this time so it's just my Jeep. If for some reason nobody in our group wants to wheel Sunday (or is broken and can't) we just have to get up early enough to get to the staging area in time to hook up with another group. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: June Big Dogs Mon Jun 01, 2009 7:42 am | |
| well knocked some stuff off the list but added shit as well
3 install ram skid 6. cut redrill track bar bracket 8. install rear axle breather 9. install fuel breather 11. install electric fan wiring 12. rear bump stops 13. limiting straps 14. gear oil 15. fix grease fitting 16. grease fitting protection 17. grease 18. install OBA stuff 19. Pack up jeep
20.remake tube fenders 21.redo tie rod 22. install new pitman arm _________________ "A yahoo made dangerous with power tools"  MARR step up or step out Who me? I didn't do it and you can't prove it. Also by chance do you have a lighter? |
 | Subject: Re: June Big Dogs Mon Jun 01, 2009 9:00 am | |
| I know the feeling with the list getting longer with the more things ya fix. at least its a lot of small stuff so Puter in 3rd gear and see ya this weekend. |
 | Subject: Re: June Big Dogs Mon Jun 01, 2009 9:31 am | |
| At the campground will tow rig and trailer be close to the tent area? Would like to keep all my stuff in truck and on trailer just didn't know were truck and trailers get parked. Thanks I know I'm a pain in the ass but i am a virgin to here. _________________ "PROVE IT OR SHUT UP"
Chuck
 | Subject: Re: June Big Dogs Mon Jun 01, 2009 11:31 am | |
| - SPP YJ wrote:
- At the campground will tow rig and trailer be close to the tent area?
If you are staying in Camp 6 with everyone else, your truck and trailer will be right at the camp site. I believe that they are requesting that trailers be left elsewhere if you are going to another camp because the other campsites are much smaller. Camp 6 is a big open field with plenty of room for everything. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: June Big Dogs Mon Jun 01, 2009 11:33 am | |
| yes, when i trailer i am usually within 75 feet from the campfire. the field at camp 6 has allot of room for any rig with trailer. you will have fun  _________________ DONT FOLLOW ME!!
 | Subject: Re: June Big Dogs Mon Jun 01, 2009 12:05 pm | |
| Sounds good so my food and DRINKS can stay in truck and my dry cloths!
I had and bad camping trip to Ohio a few years ago tent was flooded and my clothes with it, now I will camp differntly. _________________ "PROVE IT OR SHUT UP"
Chuck
 | Subject: Re: June Big Dogs  | |
| June Big Dogs | |
