 need pitman arm asap
View previous topic View next topic Go down
Number of posts: 1873
Registration date: 2007-01-20
PostSubject: need pitman arm asap   Sun May 31, 2009 2:21 pm
just found out that after moving my axel forward that the pitman arm now hits my tie rod. So I need a shorter style pitman then the 5 or 6" one that the zj has.
MARR step up or step out
Number of posts: 2550
Registration date: 2007-01-19
PostSubject: Re: need pitman arm asap   Sun May 31, 2009 4:38 pm
I thought that you are running full hydro?
Number of posts: 3649
PostSubject: Re: need pitman arm asap   Sun May 31, 2009 6:48 pm
I thought that might happen. I went to a stock, no drop, pitman and it helped. You could cut the one you have and reweld it and then reinforce it externally in WV style(just add more metal until its strong enough).
[/url]http://www.facebook.com/home.php#!/profile.php?v=info&ref=profile&id=100000213229958[url]
Number of posts: 1239
PostSubject: Re: need pitman arm asap   Sun May 31, 2009 8:11 pm
i had to use the stock one and i had to drill and taper it from the top
I'm dumb
My dog ate my turtle
View user profile http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=115840864
PostSubject: Re: need pitman arm asap   Sun May 31, 2009 10:30 pm
talked to kat and it looks like I need a stock yj pitman arm. From her measurements it looks like the yj one has 2.5" of drop stock, compared to the 4.5" on the stock zj one.
Also nester i stuck with the hydro assist just so I would still have steering if something went wrong.
View previous topic View next topic Back to top
» Looking to buy asap y8 or z6
» need pitman arm asap
» ANYONE NEEDING OR LOOKING FOR A JOB ASAP????
» Need to sell asap... Alienware M15x Laptop
» Drop pitman arm FS or Trade
 :: For sale :: Wanted-
