 Waggy springs
MYYJROX
Number of posts : 738
PostSubject: Waggy springs   Tue Jun 09, 2009 1:54 pm
Hey Nester - when you were telling me about the waggy springs were you recommending I get them for the front and the rear?
93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage
02 Tahoe with Rancho lift
02 Ram Air Trans Am
PostSubject: Re: Waggy springs   Tue Jun 09, 2009 2:10 pm
I put waggy springs in front of the CJ. The centering pin is offset by 2" compared to the YJ so it will push your front axle forward 2 inches. May need to change the mount though, not sure on that.
MYYJROX
PostSubject: Re: Waggy springs   Tue Jun 09, 2009 2:14 pm
I thought he was telling me to do it for the back but now I can't remember
02 Ram Air Trans Am
PostSubject: Re: Waggy springs   Tue Jun 09, 2009 2:23 pm
same deal. You just turn the spring around and it will stretch the wheelbase by 2".
PostSubject: Re: Waggy springs   Tue Jun 09, 2009 11:06 pm
Yeah it will move the back rear. The center pin moves the rear back 2 inches you just need to make sure you will clear your gas tank. It will help clear the 38's better with out having to hack the body as much. Wheel base will also increase and help with hill climbs.
PostSubject: Re: Waggy springs   Wed Jun 10, 2009 7:58 am
IF YOU HAVE ROOM, i would put them up front and rear. i think you would feel a big difference with both done on the rocks. i would check the front for clearance and put them on the front first because you have to take it apart anyway.
DONT FOLLOW ME!!
PostSubject: Re: Waggy springs   Wed Jun 10, 2009 4:57 pm
yeah thats next a bad idea but make sure you figure for your steering first. But I would call and get quotes first. I know Randy has good prices on springs.
PostSubject: Re: Waggy springs   Wed Jun 10, 2009 6:12 pm
x25 on checking for steering clearence
MARR step up or step out
Waggy springs
» For sale: factory 4x4 front springs. Level out your pre runner!
» Whiskey Springs & Bloody Skillet Open Sunday
» Identifying springs
» Suspension with leaf springs like a truck?
» fox podium replacement dual rate springs
