 NP 435 / 205 for the YJ
SPP YJ
Number of posts : 502
Registration date : 2008-04-09
PostSubject: NP 435 / 205 for the YJ   Thu Aug 06, 2009 8:39 pm
Here is a post I started on Pirate.
Anyone know about this or have any comments?
http://www.pirate4x4.com/forum/showthread.php?t=809594
"PROVE IT OR SHUT UP"
Chuck
[/i]92 YJ Full width front D-44 W/ E-lock rear 9in W/spool 39.5 irocs
With ROCKY II pet blow up turtle
PostSubject: Re: NP 435 / 205 for the YJ   Thu Aug 06, 2009 10:36 pm
I posted this on the pirate but thought I would post again here just in case.
Okay this is a shot in the dark, but why not just swap in a AX-15 in place of the AX-5. Then focus on a 231/300 doubler like Matt has in his TJ. Sound like a easy task since its all jeep parts but not sure how hard the swap is. Good luck dude.
I'm guessing that you want to do this because you either want the strength of a trans other than the AX-5 and you might be working to find a lower crawl ratio?
PostSubject: Re: NP 435 / 205 for the YJ   Fri Aug 14, 2009 11:59 pm
http://pirate4x4.com/forum/showthread.php?t=181361
PostSubject: Re: NP 435 / 205 for the YJ   Sat Aug 15, 2009 10:43 am
read through the write up and it is a lot of work. I got a headache reading it and i like the tech stuff. why not do a complete driveline swap and just be done? If it were my jeep i would probably swap a v8 drivetrain in there and be done. I know you probably like the 4cyl and it does what you need it to do but why not upgrade?
SPP YJ
PostSubject: Re: NP 435 / 205 for the YJ   Sat Aug 15, 2009 4:29 pm
I do like the 2.5 and I think it will be staying if we go the route we are thinking.
Problems with the v-8 is keeping everything cool, HP that we don't need alot for what we do, they are noisy, also its to easy everyone puts v8's in . The 4 banger is nice for trail riding but it would not be good for Mud or racing but I'm OK with that. My toy has a 327 in it and it works good but the extra time and money it takes to make it work correct and not overheat I don't think is worth it for a trail rig. And it makes it hot in the cab and floor. There is something to say about comfort in wheeling.
Chuck
SPP YJ
PostSubject: Re: NP 435 / 205 for the YJ   Sat Aug 15, 2009 4:48 pm
I was just on pirate and some one finally told me what I wanted to know.
Its the GM 2.8 v-6 that has the same pattern as the 2.5 I have and you can easily adapt a NP435 to this gm bell if you follow novaks instructions.
http://www.novak-adapt.com/knowledge/ford_to_gm.htm
Now I think I'm getting somewhere.
Chuck
jealos-z
Number of posts : 604
Emploi : Mechanic
Registration date : 2007-09-17
PostSubject: Re: NP 435 / 205 for the YJ   Mon Aug 17, 2009 8:56 pm
Sorry Chuck my assholeness kicked in on MR Knowitall but you got your info so screw it... lol!
92 YJ (TRAIL TESTED)
NO DRAMA OR POLITICS
I GOT MARR " DON'T ASK IT WILL ASK YOU"
SPP YJ
PostSubject: Re: NP 435 / 205 for the YJ   Thu Aug 20, 2009 11:29 am
Well this job will be put on hold for now but I will still be doing this swap sometime maybe a winter job.
The reason it is on hold is Chris and I worked on this the other nite to change fluid and when I went to take out the drain plug in the transfer case the whole case almost fell out all the bolts were loose and some were out completely.
I don't know why the whole thing didn't fall out last trip but glad it didn't.
With the bolts tight now no noise FM. After this coming weekend I will take them all out and re loctite them but should be good for the weekend.
Chuck
PostSubject: Re: NP 435 / 205 for the YJ   Thu Aug 20, 2009 7:44 pm
cool I like an easy fix.
