| Subject: Lincoln 100HD for $175 Tue Aug 18, 2009 11:17 am | |
| I was in Home Depot today and saw a Lincoln 100hd on sale for $175. It was originally $390. Is this too small for welding on Jeep stuff? It says up to 1/4" steel and runs on 115v power.
http://content.lincolnelectric.com/pdfs/products/literature/e7350.pdf
I wasnt really in the market for one, but if its worth it I would go for it. Only had 1 left in Columbia. The guy said they are discontinued so thats why they are getting rid of them so cheap.
Thanks... | |
| Subject: Re: Lincoln 100HD for $175 Tue Aug 18, 2009 1:14 pm | |
| Really depends on what you are using it for. If to fix a busted shock mount or weld together small areas like a tie rod link end then it will work fine. if you are trying to weld a cage together then it will fail. The duration is the key. if it only is used a few minutes at a time then go for it. if you plan to fabricate your own suspension and weld it to the frame etc then nope. gut instinct is go for it. | |
| Subject: Re: Lincoln 100HD for $175 Tue Aug 18, 2009 4:42 pm | |
| x2. Might not be a bad cheap first welder then when you get to upgrade jump right to a 220 welder when the time is right or you have the need. | |
| Subject: Re: Lincoln 100HD for $175 Tue Aug 18, 2009 5:47 pm | |
| If it has a built in fan it will be fine that is a big deal if no fan then it will overheat .. | |
crazyjimmy LS/Locker
Number of posts : 66 Age : 62 Localisation : Hanover Md. Emploi : United States Navy Retired Registration date : 2007-03-28
| Subject: Re: Lincoln 100HD for $175 Sat Aug 22, 2009 6:23 pm | |
- x2. Might not be a bad cheap first welder then when you get to upgrade jump right to a 220 welder when the time is right or you have the need.
gotta agree a welder is better than no welder, lots can be done with a small welder, even horse trade for a bigger one some day. | |
| Subject: Re: Lincoln 100HD for $175 Sat Aug 22, 2009 9:04 pm | |
| I went back to look at it and it looked used (really dusty inside) and seemed to be missing parts on the tip. I may check the HD near my house though.. | |
| Subject: Re: Lincoln 100HD for $175 | |
