| Subject: Kim, ARB 5mm Air Line Splicer etc Mon Sep 21, 2009 9:26 am | |
| http://www.4by4connection.com/arbairlocrep.html http://www.4by4connection.com/stinbe.html | |
Kim Matzen Locker/Locker
Number of posts : 123 Age : 19 Localisation : Silver Spring Registration date : 2007-01-21
| Subject: Re: Kim, ARB 5mm Air Line Splicer etc Wed Sep 23, 2009 9:32 pm | |
| thanks, I found a brass coupler at a truck supply store. Got 2. Will replace the line with the braided kind. What do you think about a 4:1 transfer case instead of the bead locks? I have 2.72:1 now. Heard the additional traction will help break things. | |
| Subject: Re: Kim, ARB 5mm Air Line Splicer etc Wed Sep 23, 2009 9:54 pm | |
| additional traction will not necessarily break things as long as you have more control. With beadlocks so you can drop tire pressure and not bounce so much. If you want to spend the $$$$$ then an atlas will be a really good change but you will likely still bounce and have poor traction. Poor traction means you will likely pick a taller gear and try to throttle over it. if you do buy an atlas then go 5:1 | |
| Subject: Re: Kim, ARB 5mm Air Line Splicer etc | |
