| Spent the day removing wallpaper | |
+4thinga'ma'rig rockdw72 jealos-z Rockn93YJ 8 posters |
| Subject: Spent the day removing wallpaper Sat Sep 26, 2009 7:40 pm | |
| Subject: Re: Spent the day removing wallpaper Sat Sep 26, 2009 8:19 pm | |
| I bet you woodve rather been with Amy and I | |
| Subject: Re: Spent the day removing wallpaper Sat Sep 26, 2009 10:37 pm | |
| yep, no doubt about that. | |
| Subject: Re: Spent the day removing wallpaper Sat Sep 26, 2009 10:43 pm | |
| thats a good way to remove wall paper and rob | |
| Subject: Re: Spent the day removing wallpaper Sun Sep 27, 2009 9:28 am | |
| bill, i kind of liked the wall paper just kidding. are you going to line the new walls with rock crawling and mudding pics. i am sure elva would like that. | |
| Subject: Re: Spent the day removing wallpaper Sun Sep 27, 2009 11:17 am | |
| Why didn't you invite everyone over to help tear down the wall? | |
THE ROOKIE LS/Locker
Number of posts : 78 Age : 37 Registration date : 2009-08-10
| Subject: Re: Spent the day removing wallpaper Sun Sep 27, 2009 6:36 pm | |
| Subject: Re: Spent the day removing wallpaper Sun Sep 27, 2009 7:18 pm | |
| lol good times. When bill moved into that house the first thing we did was rip out a wall in his garrage. I think at one point we tried to knock it down with a couch there are pics around here somewhere | |
| Subject: Re: Spent the day removing wallpaper Sun Sep 27, 2009 8:49 pm | |
| yeah, my shoulder still hurts. that was good times | |
| Subject: Re: Spent the day removing wallpaper Sun Sep 27, 2009 10:02 pm | |
| Good thing we didn't with this wall, 6 pipes, 6 wires and a sewage drain pipe. Not compatible with wrecking couch destruction. | |
| Subject: Re: Spent the day removing wallpaper Sun Sep 27, 2009 10:06 pm | |
| Cut hole in wall and got the plywood up. Image from dining room side next to stairs. Image from living room side where Elva spent the day removing wallpaper. | |
| Subject: Re: Spent the day removing wallpaper Mon Sep 28, 2009 7:34 am | |
| open doorways are always a nice addition | |
| Subject: Re: Spent the day removing wallpaper Mon Sep 28, 2009 8:46 am | |
| Wow - that's a lot of work! Nice job. | |
| Subject: Re: Spent the day removing wallpaper Mon Sep 28, 2009 9:24 am | |
| okay so the living room is going to stay drywall. What is the plywood for? Bead board wall? | |
| Subject: Re: Spent the day removing wallpaper Mon Sep 28, 2009 12:43 pm | |
- okay so the living room is going to stay drywall. What is the plywood for? Bead board wall?
Well when i tore into the wall I removed 2 layers of wallpaper, 10 layers of paint, 1/4" drywall, 2 layers of the old wood looking paneling, followed by 1/4" plywood and then finally to the original walls....yep you guessed it slats and plaster to expose the original 2x4(actual dimention) framed wall. The Plywood I put up was 23/32 thickness used in an attempt to bring the wall out to match the floor and the stairwell to avoid gaps. I'm in the process of putting 1/2" drywall on top of it now. It will be finished with paint. | |
| Subject: Re: Spent the day removing wallpaper Mon Sep 28, 2009 3:05 pm | |
| This is your year for home improvements | |
| Subject: Re: Spent the day removing wallpaper Mon Sep 28, 2009 3:13 pm | |
| yeah, believe it or not it is good to take a break from the jeep once in awhile. got to the point of analysis paralysis with the CJ. Need to order parts and wait for them to come in. Still looking for a reputable company to build or purchase the th400. Was just going to be wallpaper in teh living room but I wanted to open the wall while we were messing with it anyway. also doing the foyer so we make the downstairs mess just once. Elva has decided to go with wood floors in the dining room to match the foyer and living room. thats easy stuff though, just takes time. | |
| Subject: Re: Spent the day removing wallpaper | |
