| Subject: YJ gears for ZJ Wed Sep 30, 2009 2:49 pm | |
| There is a guy on the Rausch forum interested in the 4.56 gears from my D30. He says they would be going into a factory 93 ZJ. He was told he "can use zj and 97-06 tj stuff". I don't know if "factory" ZJs came with high or low pinion D30s. I told him if his is low pinion then mine won't work. Anybody know if my gears will work for him if he has a HP30? | |
MonsterS10 Locker/Spool
| Subject: Re: YJ gears for ZJ Wed Sep 30, 2009 3:02 pm | |
| The zj has a high pinion 30 he should be alright | |
| Subject: Re: YJ gears for ZJ Wed Sep 30, 2009 3:29 pm | |
| From what I was reading, the ZJ didn't go to the HP30 until '99. | |
| Subject: Re: YJ gears for ZJ Wed Sep 30, 2009 3:39 pm | |
| Kat you have the gears to a High pinion Dana 30. You know that. Tell the guy to walk out side look under his jeep. If the yoke is on the top side its a high pinion and if its in the middle he has a standard or low pinion Dana 30. if he still has a question tell him to look at his rear end. The Dana 35's and Dana 44A's all came with standard pinion rears and will give him a bases to compare to. Damn Rookies | |
| Subject: Re: YJ gears for ZJ Mon Oct 05, 2009 7:28 pm | |
| 93 to 98 zjs are low pinion | |
| Subject: Re: YJ gears for ZJ Mon Oct 05, 2009 10:09 pm | |
| A 99 ZJ is a WJ | |
| Subject: Re: YJ gears for ZJ | |
