 CJ work party Jan 9-10 Project "Juggy"
Go to page : 1, 2, 3, 4  Next
PostSubject: CJ work party Jan 9-10 Project "Juggy"   Wed Dec 09, 2009 2:53 pm
Looking to get some help with the CJ. This will be to jump start the work and get a lot done. I'll be working on it all weekend and anyone that wants to stop by for a few hours or a couple days is welcome. Not setting a time, just let me know when you are coming and I'll be elbow deep in something.
1. Assemble transfer case doubler
2. Remove old tranny, transfer case and driveshafts.
3. Install new transmission. (weights about 140#)
4. Install new transfer case. (weighs about 250#)
5. Build new tranny/tcase mounting system and belly pan.
If time.
Start back half of Juggy:
1. Remove axle
2. Remove fuel tank.
3. Remove coolant pipes/ drain colling system.
4. Cut off back half of frame.
5. Determine axle position and bend some tube!
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Wed Dec 09, 2009 4:07 pm
I'm in for that. I will bring the toyota out that weekend if I haven't done that by then.
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Thu Dec 10, 2009 5:15 pm
Count me in as well
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Thu Dec 10, 2009 5:46 pm
ok, CJ will be transformed into a buggy. Loose the frame and body and start over again from the ground up
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Thu Dec 10, 2009 5:48 pm
LOL YES i knew it was coming!!!! lk
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Thu Dec 10, 2009 6:09 pm
I might have to move in for this one. this should be tons of fun.
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Thu Dec 10, 2009 10:05 pm
you know i am in.
I'm dumb
My dog ate my turtle
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Thu Dec 10, 2009 11:16 pm
I've got a set of John Deere gloves and a 1/4 drive ratchet I am holding hostage.
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Fri Dec 11, 2009 12:39 am
does this mean you'll have to rename the project?
i'll try to make it down to give you a hand.
MARR step up or step out
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Fri Dec 11, 2009 1:10 am
The gloves are mine but not the ratchet, i don't think
I'm dumb
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Fri Dec 11, 2009 8:31 am
well I was talking to nick about a buggy name and since Elva is happy with her surgery and won't be getting any enhancements then it leaves money for the project. so we were thinking project "Bodacious Buggy"....
MYYJROX
Number of posts : 738
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Fri Dec 11, 2009 12:40 pm
I'm in. Sounds like fun.
93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage
02 Tahoe with Rancho lift
02 Ram Air Trans Am
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Fri Dec 11, 2009 4:20 pm
Main Entry: bo·da·cious
Pronunciation: \bō-ˈdā-shəs\
Function: adjective
Etymology: probably blend of bold and audacious
Date: 1832
1 Southern & Midland : outright, unmistakable
2 : remarkable, noteworthy <a bodacious bargain>
3 : sexy, voluptuous <bodacious babes>
— bo·da·cious·ly adverb
and
au·da·cious
Pronunciation: \ȯ-ˈdā-shəs\
Function: adjective
Etymology: Middle French audacieux, from audace boldness, from Latin audacia, from audac-, audax bold, from audēre to dare, from avidus eager — more at avid
Date: 1550
1 a : intrepidly daring : adventurous <an audacious mountain climber> b : recklessly bold : rash <an audacious maneuver>
2 : contemptuous of law, religion, or decorum : insolent
3 : marked by originality and verve <audacious experiments>
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Fri Dec 11, 2009 7:54 pm
So I'm guessing this a party to pull the CJ apart?
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Fri Dec 11, 2009 11:49 pm
do you need a cherry picker?
I'm dumb
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sat Dec 12, 2009 1:54 pm
I was talking to Bill about this yesterday. He was thinking of renting one. I'm sure if anyone has one he would like to borrow it for a little while. He will need it for a little while to help with the build as well.
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sat Dec 12, 2009 2:36 pm
i absolutely do need a cherry picker. might just buy one if noone has one here. Once the motor is out and mounted to the mobile table then it shouldn't need lifted again (hopefully).
Kinda like what is done here.
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sat Dec 12, 2009 4:00 pm
I can steal one from work for the weekend.
I'm dumb
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sat Dec 12, 2009 4:07 pm
sweet deal, I'll take you up on that offer.
MYYJROX
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sat Dec 12, 2009 5:47 pm
Is a cherry picker and an engine crane the same thing?
02 Ram Air Trans Am
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sat Dec 12, 2009 6:21 pm
yes
I'm dumb
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sat Dec 12, 2009 9:17 pm
harbor freight have them for around $100 or so IIRC
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sun Dec 13, 2009 11:28 am
Joe you know me. I can't just buy a $100 shop crane. I'd have to look at about 100 of them before I buy one that is durable and a little more than what I would need just in case. I do have a hard time buying from Harbor Freight due to the substandard quality of materials.
2 Ton Foldable Shop Crane
8 Ton Ram
Delivers the lifting ability you need with the advantage of compact storage. Includes ram, chain and hook.
Maximum capacity: 2 ton
Ram capacity: 8 ton
Boom length: 42'' to 63-1/2''
Maximum height: 103-1/2''
Weight: 228 lbs.
ITEM 35915-0VGA
$229.99 Email link to a friend
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sun Dec 13, 2009 3:47 pm
well mr money pants why sell yourself short, go for this shop crane
LS 180B
wheeled skid steer loader
Delivers the lifting ability you need with the advantage of knocking over compact storage areas. Includes all the shit to have fun with and make money
Maximum capacity: 5200#
HP: 75hp
Boom length: 129''
Maximum height: 151''
Weight: 7,995 lbs.
price $29,000 depending on options. Email link to a friend
http://construction.newholland.com/files/tbl_s46IVDGalleryItems/DocumentVideo303/114/LS180b_spec.pdf
jocolor jjjjjjjjjjj lol!
PostSubject: Re: CJ work party Jan 9-10 Project "Juggy"   Sun Dec 13, 2009 5:47 pm
only 75hp?
Page 1 of 4Go to page : 1, 2, 3, 4  Next
» Poss. sale of 09 RZR "S" engine
» '86 Craftsman II ["Cube"] Trail/Mud Mower Build
» Project "Yoder" Redzz02's Racer
» Is it possible to "flip " a transaxle?
» How to "Fix" a new Gas Can! Great Tip!
 :: Free At Last :: Meetings and general gatherings-
