| Stinger question | |
 Number of posts : 738 Age : 46 Registration date : 2007-01-19
 | Subject: Stinger question Sun Apr 11, 2010 10:39 pm | |
| For those of you that have singers on your rigs, would you please post 2 measurements for me if you have the time: 1. the measurement of the stinger from one end to the center of the loop 2. from the top of the loop to the grill guard Thanks! _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 Number of posts : 2558 Age : 36 Localisation : Ashburn, VA Registration date : 2007-01-19
 | Subject: Re: Stinger question Mon Apr 12, 2010 12:03 pm | |
| You should do a search. Then see the ones you like and make or have one made that suits your wants and needs. I know that you can buy them but most of the guys that make them for there own rigs have reason to make each different. _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 | Subject: Re: Stinger question Tue Apr 13, 2010 12:41 pm | |
| Actually I've already started making one. Bent the tube at Bill's a long time ago. I bent it too far and ended up using the trailer and the winch to spread it back out the other day. The problem is I think it is too long. No matter which way I angle it, something just doesn't look right. I don't want to cut it until I'm sure that is the problem. I've taken pictures of ones I like but they aren't helping, that's why I wanted some measurements. The one I like the best is Chuck's. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 Number of posts : 1243 Age : 35 Localisation : north harford Registration date : 2007-01-20
 | Subject: Re: Stinger question Tue Apr 13, 2010 9:08 pm | |
| :bonericon: make it as tall and stick out as far as you can. endos are bad, mmmm-kay  _________________ I'm dumb
My dog ate my turtle
 | Subject: Re: Stinger question Tue Apr 13, 2010 11:37 pm | |
- :bonericon: make it as tall and stick out as far as you can. endos are bad, mmmm-kay
haha  _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 Number of posts : 502 Age : 40 Localisation : Stillwater,PA Registration date : 2008-04-09
 | Subject: Re: Stinger question Wed Apr 14, 2010 11:00 am | |
| 10 feet tall to center and 6 feet wide at bottom and make it out of 6" sewer pipe  _________________ "PROVE IT OR SHUT UP"
Chuck
[/i]92 YJ Full width front D-44 W/ E-lock rear 9in W/spool 39.5 irocs With ROCKY II pet blow up turtle
 | Subject: Re: Stinger question Wed Apr 14, 2010 1:25 pm | |
|  Nice. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 Number of posts : 1875 Age : 38 Localisation : Towson, MD Registration date : 2007-01-20
 | Subject: Re: Stinger question Wed Apr 14, 2010 1:44 pm | |
| kat I told you before that baby jesus kills three kittens every time someone installs one of those things. _________________ "A yahoo made dangerous with power tools"  MARR step up or step out Who me? I didn't do it and you can't prove it. Also by chance do you have a lighter? |
 | Subject: Re: Stinger question Wed Apr 14, 2010 8:17 pm | |
| I rescued 3 so it will be even.  _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 Number of posts : 3671 Age : 50 Localisation : Knoxville, MD Registration date : 2007-01-20
 | Subject: Re: Stinger question Thu Apr 15, 2010 7:59 am | |
| Kat the stinger reallly doens't have a lot of purpose. it is rare that it would actually prevent a rollover, may throw you to the side instead. Makes a good strap point on occasion. Go with what looks good to you. |
 Number of posts : 695 Age : 39 Localisation : Parkville, MD Registration date : 2007-01-19
 | Subject: Re: Stinger question Thu Apr 15, 2010 9:48 am | |
| actually yes but that would be once in 10 years taht it would have helped. then again i may have turned the jeep into a lawn dart with a stinger in that situation. |
 | Subject: Re: Stinger question Sat Apr 17, 2010 10:57 am | |
| I hope you all realize that none of this info is actually helpful. Numbers would be helpful which is why I asked for them. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 Number of posts : 972 Age : 44 Localisation : Perry Hall, MD Registration date : 2007-01-22
 | Subject: Re: Stinger question Sat Apr 17, 2010 8:16 pm | |
| use the numbers that come to your heart, they will not let you down..hehe  _________________ DONT FOLLOW ME!!
 | Subject: Re: Stinger question Sun Apr 18, 2010 10:55 am | |
| - MYYJROX wrote:
- I hope you all realize that none of this info is actually helpful.
Man some one woke up on the wrong side of the bed  Basically what were saying is that they are worthless and what ever numbers that you come up with will work fine as long as it doesn't look to goofy. if your that worried about it bring it to my shop we'll hook a chain to the back of your jeep and hang it in an endo style so you can get some true measurements. _________________ "A yahoo made dangerous with power tools"  MARR step up or step out Who me? I didn't do it and you can't prove it. Also by chance do you have a lighter? |
 | Subject: Re: Stinger question Sun Apr 18, 2010 3:44 pm | |
| The width is normally the frame width. I only use my stinger for bumping people, well nick uses it to bump his own jeep. I did hear a good idea about how to use it to aid in taking a shit in the woods. Mine will probably come off soon if you want it. _________________ I'm dumb
 | Subject: Re: Stinger question Sun Apr 18, 2010 10:48 pm | |
- Man some one woke up on the wrong side of the bed
No shit, Sherlock. The problem is just what you said - "it looks goofy". I already have the tube the right width & it has the bend I want (so thanks Matt but I'm all set). No matter what angle I put it at, it doesn't look right. I think it's probably just too long. The numbers will help me compare what I have to how others are set up...then I'll have an idea of what I need to do. It's for looks only. I want one - nuff said. I'm not building it for function. So if y'all don't wanna help, I'll just take a tape measure to Big Dogs and charm some other guys into letting me measure theirs.  _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: Stinger question Sun Apr 18, 2010 11:18 pm | |
| - MYYJROX wrote:
- So if y'all don't wanna help, I'll just take a tape measure to Big Dogs and charm some other guys into letting me measure theirs.
This is what you should have planed to start. We are all professional ball buster. You set yourself up. Us guys so far have just been pretty nice cause if one of the guys would have came to the table with this kinda question. It would be flame on. _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 | Subject: Re: Stinger question Mon Apr 19, 2010 9:57 am | |
| You can bust whatever you want...I can take it. Shouldn't be in this group if you can't handle abuse. But last I checked, aren't we supposed to help each other when someone asks for it? _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: Stinger question Mon Apr 19, 2010 11:23 am | |
| I only remember 1 stinger in our group and nobody else is going to be of any help. |
 | Subject: Re: Stinger question Tue Apr 20, 2010 7:03 pm | |
 | Subject: Re: Stinger question Tue Apr 20, 2010 8:11 pm | |
| LMAO!! Now that was funny Danny!!! _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
Eskimo LS/Locker
 Number of posts : 76 Age : 43 Localisation : Danville, PA Registration date : 2009-10-20
 | Subject: Re: Stinger question Wed Apr 21, 2010 12:08 pm | |
| I can measure mine if you want.. I like having it as much as I dislike having it... if that makes sense.  |
 | Subject: Re: Stinger question Wed Apr 21, 2010 1:03 pm | |
| I would appreciate that - thank you. I was able to get some numbers and I can already tell from those that my pipe is about 3 inches too long at each end. _________________ 93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage 02 Tahoe with Rancho lift 02 Ram Air Trans Am
 | Subject: Re: Stinger question Wed Apr 21, 2010 11:45 pm | |
| - MYYJROX wrote:
- my pipe is about 3 inches too long
That's what she said... |
 | Subject: Re: Stinger question  | |
