 vons new buggy build
Go to page : Previous  1, 2, 3, 4  Next
PostSubject: Re: vons new buggy build   Sat Sep 18, 2010 7:44 am
i want to get some h1 rims re-centered for my next set of tires... i am suppose to get them off a guy i know. just have to make time to get them
and come up with the money as well..HE HAS 4 H1 RIMS WITH METAL INSERTS FOR THE DOUBLE BEADLOCK FOR 300.00,
I THOUGHT THAT WAS AN O.K PRICE
THEN I CAN GET THE TIRES I WANT
IT'S ALL GOING TO COME TOGETHER IN TIME..... 9
DONT FOLLOW ME!!
MYYJROX
Number of posts : 738
PostSubject: Re: vons new buggy build   Sun Sep 19, 2010 8:07 am
Sounds like a possible road trip...
93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage
02 Tahoe with Rancho lift
02 Ram Air Trans Am
Eskimo
Number of posts : 76
Registration date : 2009-10-20
PostSubject: Re: vons new buggy build   Tue Sep 21, 2010 12:27 pm
Don't go cutting down those magnesium inserts with a grinder! 9
MonsterS10
Number of posts : 267
PostSubject: Re: vons new buggy build   Tue Sep 21, 2010 1:32 pm
use a torch saw2
PostSubject: Re: vons new buggy build   Tue Sep 21, 2010 10:34 pm
he has the after market inserts that were bought, it is just 2 pieces of metal framing that goes in the tire....someone on pirates 4x4 makes them
here are a few more pics
GOING TO START THE REAR AXLE SOON!
DONT FOLLOW ME!!
88blazeron40s
Number of posts : 280
Emploi : EDMS
PostSubject: Re: vons new buggy build   Wed Sep 22, 2010 9:35 am
looks like its coming together von
PostSubject: Re: vons new buggy build   Wed Sep 22, 2010 8:56 pm
get an average of 40 minutes a day on it......allready have all the plumbing done, the engine is running and front seats are in
ALLOT TO DO YET!
EXHAUST
REAR SEATS
ALL SEAT BELT HARNESSES NEED INSTALLED
REAR CONTROL ARMS NEED TO BE MADE
REAR AXLE CHUNK TO BE ROTATED 180 DEGREES - REDRILLED AND INSTALLED
REAR AXLE HUBS NEED FLIPPED
TOP PLATE FOR CHUNK NEEDS TO BE MADE
AXLE NEEDS TO BE PUT UNDER BUGGY
PROPANE TANKS NEED FASTENED
BRAKE LINES RAN
NEW WILLWOOD BRAKE PEDAL INSTALLED WITH MASTER CYLINDERS......................done
THROTTLE CABLE INSTALLED......................done
REAR DRIVESHAFT MADE
I MAY OF FORGOTTEN SOME THINGS!
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Wed Sep 22, 2010 9:57 pm
king
PostSubject: Re: vons new buggy build   Thu Sep 23, 2010 7:25 am
oh yeah, CUP HOLDERS lol!
MY RADIATOR FROM THE OLD BUGGY BARELY FIT IN THE FRONT.....WAS TIGHT.
DONT FOLLOW ME!!
MYYJROX
PostSubject: Re: vons new buggy build   Thu Sep 23, 2010 6:36 pm
Can't forget the up holders. lol!
Looking good!
02 Ram Air Trans Am
PostSubject: Re: vons new buggy build   Thu Sep 23, 2010 7:08 pm
Looking good!
Thats funny that you guys are so stuck on cup holders. Leave a open beer in a cup holder and the first thing that will happen is Von will bump something and your going to spill your beer all over your lap.
PostSubject: Re: vons new buggy build   Thu Sep 23, 2010 8:07 pm
not if they are 1/2 drank lol! king
DONT FOLLOW ME!!
MYYJROX
PostSubject: Re: vons new buggy build   Thu Sep 23, 2010 8:29 pm
Come on Nester, don't you know that cup holders are VITAL in buggy construction? 4 jjjjjjjjjjj
I have already mastered the art of controlling 2 open bottles & not spilling them
AND not falling out of the buggy...despite being bounced around
...but you still need a place for the refill bottle. lol!
02 Ram Air Trans Am
PostSubject: Re: vons new buggy build   Thu Sep 23, 2010 11:18 pm
I guess I don't understand. Game on Von.
PostSubject: Re: vons new buggy build   Sun Sep 26, 2010 12:08 pm
the cross bar behind the seat needs to be raised about 6 inches to give more leg room for passengers in the back. it should be even will the harness holes in the seat when is is done
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Sun Sep 26, 2010 8:52 pm
installed the new master cylinder today
DONT FOLLOW ME!!
MYYJROX
PostSubject: Re: vons new buggy build   Sun Sep 26, 2010 9:52 pm
Looks like you just wanted to take a picture of your legs. lol!
02 Ram Air Trans Am
PostSubject: Re: vons new buggy build   Thu Oct 07, 2010 8:30 pm
some pics of the process of chunk flipping 180 degrees
i cut the old diff cover off and i have easy access of the inside of the chunk....so i took advantage of it
i took out all the studs but 4 of them (the 2 end ones on each side)
i installed the chunk on the axle
then i sprayed some paint into the theaded holes from the inside of the axle
the result is this
here is a whole top view of where i have to drill the new holes in the chunk
now it should be as simple as redrilling the holes properly and re-installing the chunk
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Fri Oct 08, 2010 6:55 pm
put my front brakes on today
DONT FOLLOW ME!!
MYYJROX
PostSubject: Re: vons new buggy build   Fri Oct 08, 2010 7:10 pm
Nice! I like the red center.
02 Ram Air Trans Am
PostSubject: Re: vons new buggy build   Fri Oct 08, 2010 9:14 pm
coming along. needs less RED. reminds me of those damn redskins
PostSubject: Re: vons new buggy build   Sat Oct 09, 2010 8:05 am
TO BE RED OR NOT TO BE RED......THAT IS THE QUESTION!
MY KIDS WANTED TO PAINT IT ....SO I LET THEM
THEY LIKE MAKING THINGS DIFFERENT COLORS (ITS MAGIC)
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Sat Oct 09, 2010 6:29 pm
here is the completed chunk rotation on the rear axle
its not red yet!!
I ALSO WELDED ON THE MOHAWK DIFF COVER TODAY mbn
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Sat Oct 09, 2010 8:31 pm
king
PostSubject: Re: vons new buggy build   Mon Oct 11, 2010 7:13 pm
took the axle home today.....wheeled it right in place with my wheel dollies..... mbn
DONT FOLLOW ME!!
Page 2 of 4Go to page : Previous  1, 2, 3, 4  Next
» "Southern Styled" & "Don't Judge" Double Florida Style Swamp Buggy build
» Snow and Show Murray Monster Mow Build
» The Build Sheet
» lawnmmower buggy
» How can i build a dullie tractor?
