 vons new buggy build
Go to page : Previous  1, 2, 3, 4  Next
88blazeron40s
Number of posts : 280
Emploi : EDMS
PostSubject: Re: vons new buggy build   Tue Oct 12, 2010 10:08 am
nice!
PostSubject: Re: vons new buggy build   Tue Oct 12, 2010 11:14 pm
Can we get some full pics of the rig? We keep getting these little snap shots.
PostSubject: Re: vons new buggy build   Sun Oct 17, 2010 8:21 pm
it is kind of hard to get a good pic of the entire rig right now because there is not much room in my garage......but here is the best i can do.
i still do not have the back axle hooked up yet
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Sun Oct 24, 2010 8:47 pm
installed the rear double tri-angulated arms today and finished the hub flip on another wheel.....
i have 1 more side to do
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Thu Oct 28, 2010 6:05 pm
well i pulled it outside without steering hooked up, just to feel like i accomplished something
took some pics and backed it back in the garage
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Thu Oct 28, 2010 8:50 pm
You are not going to like the lack of vertical seperation (possible negative seperation on the front) on the frame side.
I'm dumb
My dog ate my turtle
PostSubject: Re: vons new buggy build   Thu Oct 28, 2010 10:52 pm
Is that cause the upper control arms are so much shorter than the than the lowers? Why not just a 3 link front?
Von I hate to sound like I'm raging on you but dude how many pieces of metal make up any one of your front control arms? Last time you did this I remember you with a high lift trying to bend them back straight. I understand the budget friendly build. Please understand when I look at that this first things that come to mind are safety and the head ache of one of them bending or breaking ( I don't care how good you or anyone weld). Aside from the front control arm materials and lay out I like the direction this is going. With the extra seats and Kats required comfort mods this new rig be named the thingamalimo. dfjsksdkfjsd
PostSubject: Re: vons new buggy build   Thu Oct 28, 2010 11:16 pm
I think he said they were from his old rig and was just using them till he could afford good ones. But agreed the sooner there replaced the better.
MARR step up or step out
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 12:13 am
On the front frame side the upper looks like it is mounted lower then the lower mounting point. This is going to make the rig feel very tippy. Even by just reving the engine it is going to lean. I would try to raise the upper so its 4" higher then the lower. Same with the rear.
I'm dumb
88blazeron40s
Emploi : EDMS
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 8:34 am
good god whats the wheelbase on that thing? it does kinda look like a limo its long as hell!! you are def going to need that 4 wheel steer with that rig
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 8:39 am
i have to take a good look at the mounting........i was trying to keep the arms tucked up above the frame to keep them from getting caught on things or damaged....to keep my ground clearance higher......i can always change their position later if it does not feel right.
the lower arms ON THE FRONT are reused from the old rig until i get new joints and tubing $$$$$.......LIKE JOE SAID....
i still have allot of thing to do....which includes welding everything on the entire rig again, alot of tack welds to go over
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 8:41 am
wheelbase is around 116 inches...... 28 inches of ground clearance with my 38.5 on it
DONT FOLLOW ME!!
88blazeron40s
Emploi : EDMS
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 8:49 am
only 116" it looks so much more maybe its just the pics! and are you going to do the rear steer?
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 8:57 am
but of course.........just have to buy another cylinder and plumbing for it
DONT FOLLOW ME!!
MYYJROX
Number of posts : 738
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 9:28 am
thinga'ma'limo is a good name.
It is long as hell & getting in it (especially in the back) is like climbing on a jungle gym.
But once inside...ahhhhhh very comfortable.
Maybe the cup holder should be changed to a champagne chilling bucket. lol! (just kidding - I don't like champagne)
93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage
02 Tahoe with Rancho lift
02 Ram Air Trans Am
twdjeepgod
Open/Locker
Open/Locker
Number of posts : 26
Registration date : 2009-09-21
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 9:36 am
i have a 10" single ended ram w ram mount and steering arm that you could use to get your rear steer closer to working. i would sell the stuff cheap. i used to run it on my frt rock but just swithced over to a double ended ram. and just so you know the 10" will work fine with a rockwell, some guys think it will "over steer" the u-joints in the shafts but it was never an issue for me. i used this set up for 5 years with no issues
pm me if interested
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 9:39 am
116 is what the CJ is now. Agree that from the pics it looks super long. looking much safer than the last one. 9
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 10:24 am
thanks......how much for the cylinder assy.?...i have an 8 inch for the front, but that bottoms out the stops anyway (by very little) i suppose there is no difference from the 8 or 10 inch then
DONT FOLLOW ME!!
twdjeepgod
Open/Locker
Open/Locker
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 11:33 am
you only want the cylinder or everything? i have the high steer arm (cut and welded stock arm, held up great, with tappers for studs) and the ram mount for the cylinder also. if you didn't see that i wrote that above?
if i were you i would grab a 10" for the frt and run that 8" on the rear. i removed my steering stops completely in the frt. again this created no issues at all!!! i never broke a u-joint and i am not easy on my tuggy at all!!
i will let the ram go for $50, the whole set up for $100
its located in pennsburg,pa
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 7:43 pm
If he wants it I'll be racing this weekend and can run parts for him.
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 8:58 pm
i will take everything you have for the $100.00 .....(high steer arm and all)
bill what did you have in mind for the parts pickup
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Fri Oct 29, 2010 10:08 pm
I could pick it up at Rausch saturday after the race. It would at least get the parts to Maryland.
PostSubject: Re: vons new buggy build   Sat Oct 30, 2010 7:41 am
bill, are you ok with the $100.00 ...can i pay you when i pick them up from you?
i will call you
twdjeepgod.....can i get you #..pm me
DONT FOLLOW ME!!
PostSubject: Re: vons new buggy build   Sat Oct 30, 2010 7:51 am
yep, i can pay him and you can pay me later. team 696 green excursion. you have my number and can give it to him. 2408181004
twdjeepgod
Open/Locker
Open/Locker
PostSubject: Re: vons new buggy build   Sat Oct 30, 2010 8:20 am
sorry not going to race today
i pm'ed my info
thxs alot
the parts aren't going anywhere so we will work out a time for you to grab them
thxs
Page 3 of 4Go to page : Previous  1, 2, 3, 4  Next
» "Southern Styled" & "Don't Judge" Double Florida Style Swamp Buggy build
» Snow and Show Murray Monster Mow Build
» The Build Sheet
» lawnmmower buggy
» How can i build a dullie tractor?
