 disc brake conversion
88blazeron40s
Number of posts : 280
Emploi : EDMS
PostSubject: disc brake conversion   Wed Sep 22, 2010 9:42 am
i got all the stuff pulled off my old front axle and decieded to use it on the rear
picked up the new master cylinder from the gm guy by my shop
and i made the ladder bar mounts
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Mon Oct 11, 2010 5:14 pm
got the ladder bars finished on friday
MonsterS10
Number of posts : 267
PostSubject: Re: disc brake conversion   Mon Oct 11, 2010 6:15 pm
i like the antler on the work bench
PostSubject: Re: disc brake conversion   Mon Oct 11, 2010 7:17 pm
nice work 9
DONT FOLLOW ME!!
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Tue Oct 12, 2010 10:04 am
yeah i found that on my test drive through the woods! thanks i hope it works out good!
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Mon Nov 01, 2010 10:16 am
i did a 6" dovetail on the front end 3" on each side
and i had to relocate the battery to behind the pass seat
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Mon Nov 01, 2010 10:19 am
and this was a little present to myself Smile
PostSubject: Re: disc brake conversion   Mon Nov 01, 2010 1:11 pm
great investment! looks like it is coming along nice. gonna be ready for the test run?
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Mon Nov 01, 2010 2:32 pm
yeah i finished it up on sat im good to go for the 13th
PostSubject: Re: disc brake conversion   Mon Nov 01, 2010 4:30 pm
I've gotta fix the YJ, motor is running like crap. probably a bad sensor
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Mon Nov 01, 2010 4:34 pm
did you do a tune up when you replaced the distributor if not check all the contacts and rotor button on the cap might be a bad connection! what sensor do you think is bad?
PostSubject: Re: disc brake conversion   Mon Nov 01, 2010 6:44 pm
funny thing is that it would run great and then suddenly run like crap. then if I open it up and race around it would run better again but this last time out it ran like crap and didn't change. codes include cam sensor, o2 sensor, injector code, TPS code etc etc.
I'm gonna erase it's memory and start over. I'll check all connections and make sure there isn't a shorted wire somewhere or corrosion in the dist cap etc.
It's done a lot of sitting lately. I'll be using this for wheeling and the CJ only for racing.
PostSubject: Re: disc brake conversion   Mon Nov 01, 2010 8:14 pm
nice hood pins buddy.
PostSubject: Re: disc brake conversion   Mon Nov 01, 2010 8:48 pm
nice job mbn
DONT FOLLOW ME!!
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Tue Nov 02, 2010 8:08 am
ok well let me know if i can be of any help
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Tue Nov 02, 2010 8:11 am
yeah yeah i know its my ghetto bling jjjjjjjjjjj
thinga'ma'rig wrote:
nice job mbn
thanks just trying to do some things i always wanted to try my hand at
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Wed Nov 03, 2010 8:17 am
got the new art carr shifter in and it works great!!!! now i wont have to worry about the driveshaft knocking me outta gear
i am gonna cut the center console flat and put a piece of sheetmetal across the top so i can mount the shifter base plate to that
PostSubject: Re: disc brake conversion   Wed Nov 03, 2010 11:26 am
love my shifter, good choice.
PostSubject: Re: disc brake conversion   Wed Nov 03, 2010 11:45 am
When are we going to start bending tube for that SOB.
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Wed Nov 03, 2010 1:36 pm
yeah thats what everyone says about the art carr for the 700r4 that it is the best and it is def nice! did you modify your gates at all bill?
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Wed Nov 03, 2010 1:38 pm
i would love to start bending some tube but i need a bunch of little shit first before i start on that job! i need gears and i want to get that 205 xcase in there too but we will see what happens
PostSubject: Re: disc brake conversion   Wed Nov 03, 2010 1:54 pm
no, in the situations that we are shifting it was more important not overshifting and mission gears while bouncing all over the place.
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Wed Nov 03, 2010 2:08 pm
oh ok that would make sense! i though about cutting the one nub off at 3 so i could go from 4 to 1 but i am gonna play with it first before i hack it off
PostSubject: Re: disc brake conversion   Wed Nov 03, 2010 4:14 pm
yeah ya gotta have that "feel" of which gear you are hitting so don't take it all the way off if you do end up shaving it.
88blazeron40s
Emploi : EDMS
PostSubject: Re: disc brake conversion   Wed Nov 03, 2010 4:33 pm
yeah and thats why i dont think i will touch it but ill just have to get used to it
» Disc brake on transaxle
» Front drum brake conversion for your atlt!
» Rhino Rear Brake AWFUL Noise -- Normal??
» RZR Parking Brake Threads
» Rhino Rear Brake?????
