 Is a selectable locker in the front really worth it?
PostSubject: Is a selectable locker in the front really worth it?   Wed Dec 29, 2010 12:40 am
Yup I figured its something for everyone to chime in about and bring this place back to life.
I run a lockright in the front of my YJ. There are some times when I wish I could unlock the front, to help with turning and taking the load off the front. Is it worth it. I would guess no, not for the cost of the selectable lockers.
MYYJROX
Number of posts : 738
PostSubject: Re: Is a selectable locker in the front really worth it?   Wed Dec 29, 2010 10:23 am
I'll play. I say yes.
I like being able to turn them on and off when needed.
93YJ, D60 front, 9" rear, ARB front/rear, 4.56, 38" Super Swamper TSLs, SOA, RaceCraft seats with harnesses, crusher corners, custom tube fenders & cage
02 Tahoe with Rancho lift
02 Ram Air Trans Am
Eskimo
Number of posts : 76
Registration date : 2009-10-20
PostSubject: Re: Is a selectable locker in the front really worth it?   Wed Dec 29, 2010 12:34 pm
My vote is, as long as you have the ability to go into 2 low in your t-case, then not really, for recreational wheeling.
When I disconnect the front output of the t-case, I can hear the front locker ratcheting and I don't feel that it's preventing me from turning. I also like the idea of hammer-down, it's locked. Let up and steer, it'll ratchet, then hammer down again and it's locked.
Sure beats the mandatory tattoo / window sticker "Are both my tires turning" with an ARB.. asdyuysigidfdjbisd
PostSubject: Re: Is a selectable locker in the front really worth it?   Wed Dec 29, 2010 2:41 pm
Since you already have a locker i don't think its worth switching it out. unless you need to change the carrier or something. I am getting away from the arb. I haven't had a lot of issues but I don't think it was worth it.
I'm dumb
My dog ate my turtle
PostSubject: Re: Is a selectable locker in the front really worth it?   Wed Dec 29, 2010 3:03 pm
There was a discussion of this for guys building the race rigs and they all seemed to favor a selectable rear. This logic is of course based on off road only but the idea is that you can point the front wheels in the direction they need to pull you and with the back unlocked it won't try and push you straight. May no be applicable to what you're asking but I thought it was an interesting discussion. I believe it was on the Rausch board if you want to look it up.
PostSubject: Re: Is a selectable locker in the front really worth it?   Wed Dec 29, 2010 5:31 pm
That is a very interesting angel to look at it. I would say that Rich hit the nail on the head for my type of wheeling at least. I have the 2wd low for both rigs I should just learn to use it more.
PostSubject: Re: Is a selectable locker in the front really worth it?   Thu Dec 30, 2010 11:47 am
Don't waste your money. Unlock the hubs for street. Look at the cost/benefit. How often do you wheel? selectable locker is a BIG expense. Would you buy $800 golf clubs if you only golf 2-3 times a year? Money is better spent somewhere else.
PostSubject: Re: Is a selectable locker in the front really worth it?   Fri Dec 31, 2010 1:27 am
Good point I dont wheel enough.
PostSubject: Re: Is a selectable locker in the front really worth it?   Sun Jan 02, 2011 12:47 pm
well said sir.
MARR step up or step out
» Selectable locker idea
» Rzr front diff parts
» rhino front diff parts
» Honda Foreman Front Diff
» Wanted Rhino stock front rim !
