 Juggy RCQ 2011 prep
PostSubject: Juggy RCQ 2011 prep   Tue Apr 19, 2011 8:31 am
First off I will never run a 2-piece shaft again. Reason I had to run one is because the doubler made the driveline so long. I ordered an atlas 4 speed over the winter but the timing sucked, Atlas was doing a redesign and not manufacturing any. So with the 4-speed backordered til June I changed my order to a 2 speed atlas with 2:1 ratio. That ratio works great for the Juggy but we will need to get a higher stall converter. I think I'm at 1800 and with the new motor idling higher it is tough on the brakes in high range. Short list of the bigger items to change:
Atlas 2 speed, new driveshafts(x2 for spares), Cable shifters.
Mirrors - going to order the liquid iron model that Kim is running.
Suck down winch-keeps the main winch free
PSC steering pump x 2 so I have a spare, also ordering a spare pulley just in case.
Need to replace the tranny pan.
32 Gallon fuel tank, need the pickups so it doesn't starve on corners or hills. means moving water lines in rear.
Brake lights
Fix coilovers.
Install airbumps.
Parking brakes
Dyno tuning, seal computer in protective box - Todd
88blazeron40s
Number of posts : 280
Emploi : EDMS
PostSubject: Re: Juggy RCQ 2011 prep   Tue Apr 19, 2011 9:22 am
i can help out whenever just need a heads up on dates to wrench
PostSubject: Re: Juggy RCQ 2011 prep   Tue Apr 19, 2011 10:45 am
We got this!
PostSubject: Re: Juggy RCQ 2011 prep   Tue Apr 19, 2011 3:18 pm
Dont forget fuel cut off valves, and catch cans
I'm dumb
My dog ate my turtle
PostSubject: Re: Juggy RCQ 2011 prep   Tue Apr 19, 2011 4:53 pm
I just read where I need a cutoff for the fuel line, no problem. What about catch can? is that for the vent? If so I'll use a top (in/out) fuel filter and call it good.
Eskimo
Number of posts : 76
Registration date : 2009-10-20
PostSubject: Re: Juggy RCQ 2011 prep   Fri May 06, 2011 10:39 pm
Why not? I love the protection from the rocks, but they are kinda vibration prone..
PostSubject: Re: Juggy RCQ 2011 prep   Sat May 07, 2011 1:14 am
As it turns out because of my link design I have to run a 2 piece shaft. I will change the dimensions of it though so it is better protected.
Juggy RCQ 2011 prep
» Some top Grade 9 prospects this 2011 season...U15's.
» Genetrix 2011
» Sunday 2 January 2011
» Suriamas room for rent in January/February 2011
» Commonwealth 100m champion preparing for big 2011
