| | Needed: Four, Five, or Six 235/85R16, load range E | |
| | Author | Message |
big94GMC Locker/Locker
 Number of posts: 139 Age: 32 Localisation: No. VA Registration date: 2010-04-26
 | Subject: Needed: Four, Five, or Six 235/85R16, load range E Tue May 17, 2011 7:37 pm | |
| Just as the title says, I'm looking for a set of 235/85R16, E range to replace the tires, and spare, on my gooseneck. I don't need, nor can I afford, a full set of brand new tires, so I'm hoping to stumble upon a good set of used tires.
Hit me with a PM, or send me a text at (eight 5 zero) 3 8 four - 4 one zero 8 |
|  | | makitupthehardway moderator
 Number of posts: 2550 Age: 30 Localisation: Ashburn, VA Registration date: 2007-01-19
 | Subject: Re: Needed: Four, Five, or Six 235/85R16, load range E Tue May 17, 2011 11:01 pm | |
| Just a thought I went to a used tire place today to get a tire for my dads old beater. The guy charged me 30 for a good tire. He had truck tires in really good shape for 50 a piece. Still not cheap but better than paying 100+ for E load tires. _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
|  | | connordanny Locker/Spool
 Number of posts: 695 Age: 33 Localisation: Parkville, MD Registration date: 2007-01-19
 | Subject: Re: Needed: Four, Five, or Six 235/85R16, load range E Wed May 18, 2011 10:03 am | |
| These are still kinda expensive for trailer tires, but would make your trailer look awesome! http://www.treadwright.com/p-28-235-85r16-crawler-m-t-e.aspx I ordered a set of 245/75/r16 E last week for my pickup. Its kinda funny looking to see a Yoko sidewall and BFG tread, but I dont care if they are hot pink for that price. The local tire shop wanted over a grand for 4 new BFGs and these ran about $320+ shipping  |
 | Subject: Re: Needed: Four, Five, or Six 235/85R16, load range E Thu May 19, 2011 2:22 pm | |
| Erick, where did you go??
Connordanny, I want to stay away from retreads. Lost a tread cap on this last trip out. So, looking for a decent set of virgin rubber. Thanks for the suggestion, though. |
 | Subject: Re: Needed: Four, Five, or Six 235/85R16, load range E Thu May 19, 2011 10:21 pm | |
| There is two used tire places in sterling. The prices very from 30-50 a tire for the most part depending on the tire. I would think if you called to check first you should be able to find tires for around 200 all said and done. _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
|  | | 88blazeron40s Locker/Spool
 Number of posts: 280 Age: 27 Localisation: Ashburn, VA Emploi: EDMS Registration date: 2010-05-05
 | Subject: Re: Needed: Four, Five, or Six 235/85R16, load range E Fri May 20, 2011 12:00 pm | |
| there is a place in wincester that i got trailer tires from and they do used tires as well i will try and find the name of the place for you |
Similar topics |  |
| | Permissions in this forum: | You cannot reply to topics in this forum
