| HELP! SOA on CJ7 in EDGEWOOD! | |
+5timberwolf Chris Taylor SLeach el_flasko Dirt Diggler 9 posters |
Dirt Diggler Open/Open
Number of posts : 9 Age : 40 Localisation : Edgewood, MD Emploi : US Army Registration date : 2007-11-09
| Subject: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 12:40 am | |
| Ok so I am in need of some help here. I am new to the Baltimore area (Edgewood) and I don't know any other off-road enthusiasts and have JUST submitted my application to join the "Rock Raiders". I am attempting to do a SOA but am wary of what my happen with this being my first attempt.
I am looking for ANYONE who may want to undertake this with me as a project.
I have a 85 CJ7 with a 4" pro comp lift, 2" shackels, 3" body lift and running 33x12.50 Baja Claws. What all do I need to do to make a SOA work and are there any good websites for people that HAVE done it.
In addition does anyone know where to get an "eye to eye" convertor for shocks (i.e. Rancho RS9000XL).
And LASTLY does anyone know a round about figure of cost or basic component list or if I were to take it to a shop to have this done. One place told me an ABSURD $4,000!!!
Thanks,
Matt McCloy US ARMY | |
| Subject: This is the CJ7 Fri Nov 09, 2007 12:46 am | |
el_flasko LS/Locker
Number of posts : 53 Age : 50 Localisation : Abingdon, MD Emploi : Resident Mortgage Guy Registration date : 2007-11-07
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 12:50 am | |
| Matt, couple thoughts. If you have 4" springs, 2" shackles and 3" bl, you're already at 9" of lift if you kept the thing sua. Going SOA is going to put you up another 4-5" (roughly). If you're planning on sticking with 33's for a while, might want to stay sua for now...that's MORE than enough lift without going SOA. (a good bit too much imho) I did a SOA on my YJ with 1.5" springs, no body lift, and maybe 3/8" lift on the shackles I used and I have MORE than enough room for 36" tires... Bad pics, but you can see the clearance... Are you planning for different axles, tires etc...little more detail will help others advise ya | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 1:05 am | |
| Thanks, nice jeep.
Yeah I have D44 front and rear with a 283 small block. I want to get rid of the body in doing the soa. I am looking into getting some 38 boggers/baja claws.
With all that said I think really all I have to do is get a traction link bar and some new perches and flip the springs. My only real concern (I think, better yet hope) is the rear pinion angle and dropping the transfer case. | |
el_flasko LS/Locker
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 1:13 am | |
| Agreed on pinion angle, but also consider steering angles, and DS angles...I assume you have a SYE or will be doing one for the rear? | |
| Subject: SOA Fri Nov 09, 2007 1:26 am | |
| Yes I have a SYE already but I am planning on only using traction bar and a larger perch to prevent leaf wrap. You know of any shops around here that aren't outrageous?? I could do it at the MWR (on post at APG) but that place doesn't offer half the stuff needed.
So is this a pretty good club for around here? I am from Ga and all we did growing up was trail rides, crawling, and mudding. | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 1:28 am | |
| And for steering I am guessing your talking about the driveshaft linkage (??). Which I will have to extend and I am not sure if I should fabricate it or buy a whole new CV. | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 3:01 am | |
| look up jeep forum.com i know under the yj section there is a thread dedicated to soa while its not for a cj it may tell you what you are getting into | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 10:30 am | |
| I'm in BelAir and could help. Never done one but I can turn a wrench. | |
timberwolf LS/Locker
Number of posts : 62 Age : 52 Localisation : Parkville, Md Registration date : 2007-11-02
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 11:10 am | |
| - Dirt Diggler wrote:
- Ok so I am in need of some help here. I am new to the Baltimore area (Edgewood) and I don't know any other off-road enthusiasts and have JUST submitted my application to join the "Rock Raiders". I am attempting to do a SOA but am wary of what my happen with this being my first attempt.
Thanks,
Matt McCloy US ARMY matt, with your current set up i wouldnt go adding spring over for safety sake. it would end up way too tall. your center of gravity would be too high and would bee too easy to roll over. now what you could do to go soa is buy like 2 inch springs and maybe 1 inch shackles. my recommendation is stick with what you have. looks good and you should have the room for larger than 33's tires. fyi... try this website www.cjoffroad.com its packed with nothing but cj info. i found it very useful for my cj... | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 11:41 am | |
| You are definitely going to have to consider the height you will have once the SOA is in place with your current set up. Off camber situations and hill climbs will be quite hairy. Take a look on Pirate4x4.com and spend some time searching around. I am in Joppatowne within a few miles from you and can always help in what ever direction you decide to go. As far as shops there is The Custom Shop in Aberdeen but I dont know their labor rate. You also have Appalachian Offroad that is in Westminister which is about 45 minutes and I have heard good things about their service. There are a few others but most guys on here do their own work or work together. I am sure if you decide to tackle it we can get a work party going.. Matt | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 11:44 am | |
| I would ditch the 3" BL and go with a daystar 1" BL stick with the SUA and run 36" tires. the SOA can open another set other problems. and your dana 44 will break with 38" tire and your 283. this is just my opiion and I have problems keeping my jeep running right. other than that Nice CJ glad to have another CJ on the board. check out this site http://jeepsunlimited.com/forums/forumdisplay.php?f=36 | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 2:19 pm | |
| what type of wheeling do you do. If I were doing 38's I would streatch it. Matt mentioned about steering because with a soa you will have a problem with the drag link getting into the springs. most people fix this problem by mounting the drag link on top of the knuckle. For this you would need flat to knucles. By doing this it will also help out your bump steer and you can mount your tierod there too to keep it out of the rocks | |
| Subject: Wheelin Fri Nov 09, 2007 2:51 pm | |
| The CJ I mostly use just for mudding, light trail rides, and a daily driver. I live 2 minutes outside the back gate of APG so comfort on the road isnt important. For the trail I have an old XJ on 34x10.5.
Thanks all for your imput and help. | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 6:14 pm | |
| as for shops, you can also try Adams Jeep in aberdeen... don and the crew can hook ya up. | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 6:25 pm | |
| do they do soa's I just figured they would just do bolt on stuff | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 7:13 pm | |
| im pretty sure they can do SOA... ive seen a few done when i used to work there. i know they have done long arm lifts in the past as well as some Fabrication work. John in service would be the guy to ask if you go up there. Don in parts can hook ya up. | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 7:20 pm | |
| most long arm kits are bolt on. I went there once to see if thery had any johnny joints and they looked a me like I had two heads. I did see they had some custom bumbers in the show room that looked to be done well | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Fri Nov 09, 2007 7:36 pm | |
- most long arm kits are bolt on.
true, but there is some cutting and welding on the frame involved also. | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Sat Nov 10, 2007 12:14 am | |
| Dont go to adams jeep. everyone says there work is not the best and they are over priced. On the CJ I would stay with the SUA and look in to a 5 inch lift it. I know that BDS makes a good one for YJ's and Rubicon express makes good kits too. If you do go SOA you will have to think about what springs to run and want your driveline angles need to be and have a good welder to see it all up the right way. Then there is driveshafts with the heavy angle unless your going to stretch your wheel base. If it was my jeep I would do a bolt on kit that way its easy to do yourself and you dont have to pay a shop to weld and you keep your street ablity and a nice low center of gravity on the trails. In my personal opinion SOA is a hassel. Unless your willing to set it up right which most of the time people dont think of all the parts and labor that goes in to it. Someone who has all the tools and a shop to do it there self it works great if you dont the money is saved in a nice bolt on kit. just my .02 cents | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Sat Nov 10, 2007 1:31 am | |
| I looked into a bolt on but none fit a D44. You know of a good place?? | |
el_flasko LS/Locker
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Sat Nov 10, 2007 10:52 am | |
| If you do decide to go SOA, it's not terribly difficult to do on your own. I was LUCKY in that a guy lent me a garage with a lift in it for 2 days, and we literally finished in 2 days. The steering can be a bit tricky, but nothing too bad.
Just an opinion, and I am curious to see what rates shops are quoting you.
I have two very good friends that own 4x4 shopsin MD that will do it for you. They do a TON of work for a lot of the guys on Maryland Creepers...a few members here to I believe.
jeff@adrenalineoffroad.com 301-502-6180 Jeff is the owner and a really good guy.
OR
Appalachian Offroad Inc. (410) 848-2942
Mike Bosley is the owner there...both shops kick a$$ and do quality work...
Hope it helps...Ryan | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Sat Nov 10, 2007 1:15 pm | |
| I have pretty much all the stuff to do it, minus a traction bar for anti-wrap. People (i.e. E.C.H.O.) said it would cost like 4,000. Which is OUTRAGEOUS!!! | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Sat Nov 10, 2007 1:24 pm | |
| i.e. E.C.H.O.) = Ask Tom, red yj that wheeled with us last week, about ECHO.. They installed a transfer case for him, didnt fill with fluid, he drove home and it was burnt up and they denied it. Adrenaline pulled it apart and found no fluid and he had to fight with ECHO to pay for it.. | |
el_flasko LS/Locker
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! Sat Nov 10, 2007 5:30 pm | |
| - UPNOVER wrote:
- i.e. E.C.H.O.) =
Ask Tom, red yj that wheeled with us last week, about ECHO.. They installed a transfer case for him, didnt fill with fluid, he drove home and it was burnt up and they denied it. Adrenaline pulled it apart and found no fluid and he had to fight with ECHO to pay for it.. BIG x2...ecoh stuck it to me yrs ago when I had my TJ. Jeff at Adrenaline is a good guy, good prices and TOP notch service. Mike at Appalachian is the same way. | |
| Subject: Re: HELP! SOA on CJ7 in EDGEWOOD! | |
