| Subject: LCA Tue Dec 11, 2007 11:04 am | |
| ADQ - What size is the nut for the lower control arm on a 04 TJ where it joins at the axle? (like where you would bolt a skid row lower control arm skid plate) A 1/2 inch fits but feels loose. Auto parts store couldnt help - 14mm didnt work but may have been threading. The screw here to see what size nut you need in both auto parts and home depot didnt fit what I had. I have a problem with nuts just not wanting to stay tight. | |
| Subject: Re: LCA Tue Dec 11, 2007 1:05 pm | |
| You should try using the nuts that have the nylon lock rings on the end. If that doesn't fix the nuts coming loose problem try some lock tight. I thought that all the axle parts for the control arms used 1/2 nuts and bolts. | |
| Subject: Re: LCA Tue Dec 11, 2007 1:46 pm | |
| I thanks - I thought so but 1/2 didnt work on the try here display and felt loose as I threaded it on- you know how the threads catch but theres a touch of play. The original didnt have the nylon and the one I had that did didnt work. I just wanted to double check -- They've been doing road construction on the road to my house and these guys dont know smooth -- its like driving on a rausch road for a mile or two at 40 mph 4 times a day. I checked after last outing and all was ok but not every week. After last outing my spare nut pile is growing! | |
| Subject: Re: LCA Tue Dec 11, 2007 11:08 pm | |
| Its metric, not sure what size but next size smaller then 1/2 is 12mm | |
06rubicon Open/Locker
Number of posts : 26 Age : 48 Localisation : Frederick Registration date : 2007-01-20
| Subject: Re: LCA Wed Dec 12, 2007 3:48 pm | |
| check the thread pitch too. I think its 1.5 (I could be wrong). Try using a touch of blue (med) loc-tite to keep it from backing off. | |
| Subject: Re: LCA Fri Dec 14, 2007 6:16 pm | |
| Ok I had to add this note. Took off early from work to tighten my nuts while it was still daylight and as an excuse to just leave early on a friday. Degunked the xj and then tightened and locktighted the nuts on the TJ that I had messed with. Keep in mind I'm not that mechanical at all so I'm still learning. Still wasnt comfortable with the lower control arm nut - come to find out what i really bought but was mis-labeled at home depot (wow big suprise there) was a 5/8 not half inch. So chiltens was no help so called a jeep dealer who sent me to parts. They then told me it was a 14mm.
Now that you have the short story long -- how do you think I felt calling Ace Hardware and asking if they have any 14mm coarse thread nuts?
And they didnt even blink | |
| Subject: Re: LCA Fri Dec 14, 2007 8:19 pm | |
| thank for the update Gill. Now we know. | |
