| LCG | |
| Subject: LCG Mon Jan 28, 2008 10:01 pm | |
| For those that understand Low Center of Gravity (LCG) check out this thread. That rig is super nice.
http://www.pirate4x4.com/forum/showthread.php?t=604589 | |
| Subject: Re: LCG Mon Jan 28, 2008 10:54 pm | |
| Speaking of rich dude hahaha LCG screams Rich, he could talk about it for days. That's sweet though. | |
| Subject: Re: LCG Tue Jan 29, 2008 1:42 am | |
| It was low till he lifted it. He should of gone with 14s or mounted them though the hood. He even said it himself that he lifted to high. but he said he plans on jumping it so he might need all of that up travel. This was my favorite build on pirate till he lifted it and put the cage in. (I am not a fan of the poison spyder type cages) | |
| Subject: Re: LCG Tue Jan 29, 2008 7:33 am | |
| I like the set up on it. Thats a really good ride height not to tall not to low. | |
| Subject: Re: LCG Tue Jan 29, 2008 2:03 pm | |
| I was looking at the poison spyder cages as well and I don't like them either. Wish I could find the one on there I saw last year that i really liked. I'll have to find it in the next month or so. I like the shock hoop setup. Custom frame was nice too, couldn't tell if he narrowed the frame in the rear when he changed it or not. | |
| Subject: Re: LCG Tue Jan 29, 2008 2:23 pm | |
| I saw this rig at the Save Paragon Run...when I saw this post this is the rig that popped in my mind. | |
| Subject: Re: LCG Tue Jan 29, 2008 6:11 pm | |
| the rear frame is btf kit that narrows the frame to be able to mount Coil overs without notching.
here is some cage ideas http://www.pirate4x4.com/forum/showthread.php?t=564706
| Subject: Re: LCG Tue Jan 29, 2008 7:16 pm | |
| Yeah that frame does bend in. One of the pictures you could see the bottom side of the BTF kit that he used. | |
| Subject: Re: LCG Tue Jan 29, 2008 7:19 pm | |
| - Locked_N_Loaded wrote:
I saw this rig at the Save Paragon Run...when I saw this post this is the rig that popped in my mind. Nick, when you post pictures like that it makes me think of all the crazy mods I could do with the YJ once the Toyota is done. This sport is going to be the death of me and my wallet. | |
| Subject: Re: LCG Tue Jan 29, 2008 7:52 pm | |
| I know dude, that's the type of picture I can just stare at and dream of for a while. Just as I'm set on not going overboard I see rigs like that. | |
| Subject: Re: LCG Wed Jan 30, 2008 7:47 am | |
| yeah thats why I got the Toyota. I like to street my jeep to much. But it still fuels ideas of how you can get big tires with little lift. I think I'm doing pretty good myself. 5.5 in. lift springs with a 2 in body and I cut to clear the 37's. Its not all about the flex when your fully locked and geared right with a set of good crawl gear in the T-case. | |
| Subject: Re: LCG Wed Jan 30, 2008 10:12 am | |
| Big problem with tires that big is it dramatically reduces the turning radius due to contact with control arms or leaf springs. Unless you have really wide axles but still not as good as 35-37" tires. Good question is what is the smallest big tire you can run and be able to conquer all the trails you desire. it gets to a point where if you run tires too big then it takes all the challenge out of the smaller trails. 44" tires will make rock creek into a blue trail where 35" tires makes you consider very carefully the line you take and wary of every rock. 44" tires on a twisty blue trail and you are making 3-5 point turns at every curve in the road. I don't wish to take all the challenge out of the trail so I'll be limiting myself to 37" tires. I may also be lowering the jeep an inch or two after the tummy tuck for lower center of gravity on off camber spots. these coilovers really unload when off camber. West coast is a different story. they have rocks big enough to challenge any rig that comes its way. | |
| Subject: Re: LCG Wed Jan 30, 2008 12:10 pm | |
| That's an awesome point with west coast rigs | |
| Subject: Re: LCG Wed Jan 30, 2008 10:45 pm | |
| Yeah I'm happy with the 37's on the YJ. Items left on the rig are stuff like tube fenders which I might try to clearance the hood some. The flat belly pan and maybe work on the wheel base a little or just clearance the rear of the tub and figure for bump stops. I do need to regear to some 4:88's but that will have to wait. I still want the YJ to be a street friendly Jeep. Now the Toyota is going to be a totally different story. I might end up doing full width axles on 38-40 inch tires. | |
| Subject: Re: LCG Thu Jan 31, 2008 12:03 am | |
| I must say i'm pretty satisfied with the way my rig is setup right now. It's comfortable on the street and it is capable of running some high level trails...the only thing I miss is beating it a bit and I proved I can't do that after that yellow jacket ridge breakage. Hopefully the upgrade to the front axle and the super 88 kit will allow me to "reasonably" beat it if that makes any sense. I feel like I've reached a pretty solid goal though because I've always wanted to be capable of blacks/light red and moving to the 37"s seems to be ideal. It's always the best learning experience pushing what you have to the max even if it's the min of that max. Anyway...back to the LCG | |
| Subject: Re: LCG | |
| LCG | |
