| Subject: ARB air source backup Fri Feb 22, 2008 12:54 am | |
| I don't like relying on the york OBA setup for my arbs (and nester I'm muting you now on arb comments). If/when I have an oba failure that isn't easily trail fixed, what do you guys think my best alternative would be for backup just to lock in the arbs? I've been thinking of a setup since my arb compressor failed and I've been running the lockers off my oba. I guess I should really have a quick connect close to the solenoids. | |
| Subject: Re: ARB air source backup Fri Feb 22, 2008 12:13 pm | |
| do you still have the ARB compressor, can it be rebuilt? it is rather easy if it is just piston or valve failure. could always install a reserve tank or just don't worry about it and run without lockers when if fails. not a crisis when it goes. I have extra ARB parts in case mine fails again. | |
| Subject: Re: ARB air source backup Fri Feb 22, 2008 2:33 pm | |
| Yes I still have it...i never spent the time to see what failed on it yet but I've been wanting to get around to it and when I do i'll be sure to pick your brain. | |
| Subject: Re: ARB air source backup Fri Feb 22, 2008 2:55 pm | |
| going to Nesters wrenching party? bring it along. I may have spare parts for it as well depending on the model. | |
| Subject: Re: ARB air source backup Sun Feb 24, 2008 8:50 pm | |
| I will keep my mouth shut. | |
| Subject: Re: ARB air source backup | |
