FallstonYJ Open/Locker
Number of posts : 45 Age : 63 Localisation : Fallston Registration date : 2008-04-07
| Subject: 88 YJ transfer case rear seal leaking Fri Aug 29, 2008 12:13 am | |
| I replaced the rear seal on my transfer case a couple of weeks ago and it is still leaking; any thoughts/suggestions would be appreciated. Thanks, Tom. | |
| Subject: Re: 88 YJ transfer case rear seal leaking Fri Aug 29, 2008 11:00 am | |
| Assuming you dont have a sye, you need to replace the rear bushing in that housing. This is what usually causes it to leak but the seal gets blamed most of the time. If you go to advance, it is not the rear bearing. Acutally idont think they can get it, i work there and have searched all over the computer. You should have the np231 trasfercase and not the 208(or 207, cant remember which they put in in the first few years of the yj or for how long) you might try napa or autozone, it should be like 10 dollars | |
| Subject: Re: 88 YJ transfer case rear seal leaking Fri Aug 29, 2008 2:29 pm | |
| I would check the yoke too. If its has bad pitting on it you need to redo the seal and clean the yoke with some sand paper or emory cloth. | |
lt.dan LS/Locker
Number of posts : 89 Age : 58 Registration date : 2008-11-12
| Subject: Re: 88 YJ transfer case rear seal leaking Fri Nov 14, 2008 2:05 am | |
| if your driveshaft is out of ballance it will cause uneaven wear on the yoke, and bushing. both parts can be purchased at perry hall power equipment 410-391-2300 | |
| Subject: Re: 88 YJ transfer case rear seal leaking Sat Nov 15, 2008 12:11 pm | |
| Thanks, Lt. Dan. It seems it is a mute point now as I blew the rear last weekend at RC. Now I will be searching for a new axle; (preferably 8. , and when I have that installed I will install the SYE that I have had for a while. That plus a new driveshaft should take care of it, I hope! BTW, welcome to the club!! | |
| Subject: Re: 88 YJ transfer case rear seal leaking | |
