| NEWBIE | |
+3projblacknblue makitupthehardway 4pissedsquirrels 7 posters |
4pissedsquirrels Open/Open
Number of posts : 4 Age : 36 Localisation : Essex Maryland Emploi : Union plumber Registration date : 2008-10-11
| Subject: NEWBIE Sat Oct 11, 2008 6:40 pm | |
| Hello My name is Jason . I live in essex MD. I first met you guys at RC during your ADA run when my friends rubicon lost a u joint and thanks to tico and eric nestor our trip wasn't ruined and we have a good story to tell about our first time at RC, and thanks again nestor and tico. I drive a green and black tj with 4 pissed squirells under the hood, a 4inch mutt lift and dana44s front and rear with 4:56s and 33" swampers. | |
| Subject: Re: NEWBIE Sat Oct 11, 2008 8:46 pm | |
| Hey Jason good to see you checked our forum out. Welcome to the MRR | |
| Subject: Re: NEWBIE Sat Oct 11, 2008 9:17 pm | |
| Welcome Jason, Tico, Nester, and a ton of others (Danny, Bill, Von, Gill, Paul T. and countless others)... there are tons of great people here to help when you need it most. Hope to see you back at RC soon (mine was the heap at the main tent covered in mud... Tico bailed me out big time to get it home... and it hasn't moved since...) | |
| Subject: Re: NEWBIE Sat Oct 11, 2008 10:42 pm | |
| Hey nestor was the throttel cable the problem on the toyota? mrjeepy seen your jeep in front of the tent figured you hydrolocked Im glad that i backed out of that hole when it got a little to deep for my likings. Do most of the mud holes at RC have big rocks in them cause i would at least like to see what i'm bashing my crap against? | |
| Subject: Re: NEWBIE Sat Oct 11, 2008 11:01 pm | |
| If you stay away from "Frog Hole", "Milk Shake" the left side of the 5ft mud pit, Sunken Treasure, and anything other than the outer rim of Lake Cristy you should be fine! Those are the deep water/mud areas. Although the water at the bottom of winch hill seemed much deeper over the ADA weekend too for some reason. | |
clark687 Locker/Locker
Number of posts : 120 Age : 34 Localisation : Bel Air, Maryland Emploi : CNC Machinist Registration date : 2008-08-13
| Subject: Re: NEWBIE Sun Oct 12, 2008 12:14 pm | |
| another 4 banger yeaaaa | |
| Subject: Re: NEWBIE Sun Oct 12, 2008 6:10 pm | |
| - 4pissedsquirrels wrote:
- Hey nestor was the throttel cable the problem on the toyota?
mrjeepy seen your jeep in front of the tent figured you hydrolocked Im glad that i backed out of that hole when it got a little to deep for my likings. Do most of the mud holes at RC have big rocks in them cause i would at least like to see what i'm bashing my crap against? At this rate hydrolocked woulda been an easy fix... at least I would know what to replace... lol... still troubleshooting the problem... And like Danny said... there are a handful of places to get into trouble... I went into milkshake slow just to check depth first... I think if I had hit it with a bit more speed I woulda made it on my own... and if I worked the steering a bit longer I probably coulda gotten some side traction and crawled out like the first time I got stuck... But I stopped cause I didn't want to risk snapping a driveshaft or axle shaft/u joint... If I knew it woulda been the last run for awhile I would have really gone all out... but my wallet appreciates this enough so... Trust your guides and spotters, they have the knowledge and experience to get you through the park... Tony | |
| Subject: Re: NEWBIE Sun Oct 12, 2008 8:39 pm | |
Tony Does this mean you want to try it again I wasted one clutch in milkshake and I not sure if I want to try that any time soon. | |
| Subject: Re: NEWBIE Sun Oct 12, 2008 8:55 pm | |
| yea I only went half way in to milkshake and now when I start my jeep she makes a grinding noise like theres sand in the starter or clutch? | |
| Subject: Re: NEWBIE Sun Oct 12, 2008 8:57 pm | |
mrjeepy seen your jeep in front of the tent figured you hydrolocked Im glad that i backed out of that hole when it got a little to deep for my likings. Do most of the mud holes at RC have big rocks in them cause i would at least like to see what i'm bashing my crap against? Yeah its fixed for the moment I need to get a new cable. Frame on the other hand was about to spilt in half. | |
| Subject: Re: NEWBIE Mon Oct 13, 2008 10:43 pm | |
| There is definately A TON of sand... in fact I don't think it was mud at all... The tub still has about 1/4" thick of a layer... I won't even talk about the belly pan... Needless to say the neighborhood kids have been building sand castles around my Heep and I looked like a sea turtle digging out the exhaust and tcase... And Paul... as soon as I get those 37s on... guess where the first place I am going is... All I am saying is I gave up in the pit since I didn't want to break... had I known it wouldn't have mattered.... I woulda given it hell... | |
| Subject: Re: NEWBIE Mon Oct 13, 2008 10:46 pm | |
- yea I only went half way in to milkshake and now when I start my jeep she makes a grinding noise like theres sand in the starter or clutch?
Starter is 2 bolts... piece of cake to pull... Disconnect the ground, 1 bolt (15mm) thru starter into tranny, 1 bolt (9/16") from tranny into starter... Just hold it with one hand and wrench the other... comes right out low enough to take off the main wires (13mm I think for the big one, and small one just slid on like a speaker tab). Clean it all out nice and purdy, and re-assemble... | |
| Subject: Re: NEWBIE Tue Oct 14, 2008 10:27 pm | |
| Yea i know what this weekends project is. if i really feel like it i might put my new clutch and flywheel in while I'm at it but i'm just kidding myself but it would be nice to stop looking at the stuff | |
| Subject: Re: NEWBIE Tue Oct 14, 2008 10:43 pm | |
| Lesson is either stay out of the mud pits or save them for the end of the day. I've seen so many people hydrolock vehicles in those pits. also experienced first hand how even if you make it through the pit there will be so much mud in the radiator that it will be overheating for the rest of the day. And if you do decide to go into the pits at the end of the day, run a snorkel, don't press the clutch and have a strap already hooked to the vehicle so extraction will be quick. | |
| Subject: Re: NEWBIE Wed Oct 15, 2008 10:14 pm | |
- Lesson is either stay out of the mud pits or save them for the end of the day. I've seen so many people hydrolock vehicles in those pits. also experienced first hand how even if you make it through the pit there will be so much mud in the radiator that it will be overheating for the rest of the day. And if you do decide to go into the pits at the end of the day, run a snorkel, don't press the clutch and have a strap already hooked to the vehicle so extraction will be quick.
hand throttle or stay on the gas Don't shut off the motor Don't forget the lucky horseshoe (did all of the above except snorkel, and still had issues... but that's what makes it fun ) | |
| Subject: Re: NEWBIE | |
| NEWBIE | |
