| Subject: wheel bearing Tue Apr 03, 2007 6:30 pm | |
| I am looking for a hub bearing for a TJ. Need somthing tie me over for a few months, Till I can get rid of the dana turdy. I already missed to many wheling trips and topless days driving around. | |
| Subject: Re: wheel bearing Wed Apr 04, 2007 7:08 pm | |
| Hey Matt, I bought spare shafts off ebay recently and they came with the bearings attached. We can pull the bearing off the shaft if you want to use it. Is it just the big 36mm nut holding the shaft onto the bearing assembly? let me know. Dan | |
| Subject: Re: wheel bearing Fri Apr 06, 2007 2:53 pm | |
| Yeah I think thats it. I would soak it down with some PB blaster a couple times before you try cranking on the bolts. | |
| Subject: Re: wheel bearing Fri Apr 06, 2007 7:05 pm | |
| let me know if you still need one I have three already pulled and sitting at my yard if you need one. | |
| Subject: Re: wheel bearing | |
