Subject: Reservoir Wed Nov 03, 2010 2:15 pm
Anybody have a windshied washer fluid reservoir for a YJ laying around?
Subject: Re: Reservoir Wed Nov 03, 2010 8:19 pm
What is wrong with the one you have? I'm guessing it leaks. If thats the problem they sell a product called seal all that will take care of that. If its the pump they sell new pumps. Now if the thing is destroyed then yeah you might need a new one.
Subject: Re: Reservoir Wed Nov 03, 2010 10:28 pm
It leaks. I put silicone on it months ago and thought that fixed it but apparently not cuz when I filled it up, half the bottle came back out in a slow drizzle. I just caught it in a bucket & put it back in the bottle.
Subject: Re: Reservoir Thu Nov 04, 2010 12:02 pm
Just take your windshield off...problem solved. Then again, with no fluid you can't spray your passenger.
Subject: Re: Reservoir Thu Nov 04, 2010 11:43 pm
Its called "seal all" and they sell it at most auto parts stores. I used it on my gas tank and two years later it still works. Silicone is good but doesn't always bond to plastic with a true waterproof seal.
88blazeron40s Locker/Spool
Subject: Re: Reservoir Fri Nov 05, 2010 9:49 am
you need to melt the plastic back together first along the split and then use that seal all
Subject: Re: Reservoir Sat Nov 06, 2010 11:01 am
Hmmm - the split is tiny...a seam came apart. I wonder if melting it alone will do the trick.
