K... so As you know I am having alignment issues with the frame to the axle.
Question... if it is going to be a couple grand to get this all worked out, would I simply be better off putting that into a long arm kit.
That would replace the frame mounts (which are probably bent anyway) replace the arms (might be tweaked to)...
In short it would basically replace all the suspension mounts on the frame getting me a fresh start on centering the axle.
Of course this may be jumping the gun a little depending on what george come up with. Just venting a little to friends I guess.
Laurie and I might be right seating a few runs til this is all worked out, but it hasn't dicouraged my interst in the least bit.
If anything I just know my weaknesses, and what to do to make it stronger.
Now the hunt for a tow rig that can be the DD.
