I have the following I want to sell.
GM smallblock bellhousing
clutch fork
flywheel(should be machined,I can have it done for $40.00)
clutch Has about 98%life left
GM-T90 adapter with shaft
starter
All works fine,gear on shaft has scoring and a few nicks in it. This is the part of the trans. that actually hasn't given me trouble! Depending wich T90 you have, you may not need this shaft.
I'll also give you a T/O bearing to match up a new one, this one isn't any good.
I want $200 for all of it. Let me know if you want pic.s
Check out the kit price on Novaks site. Thats just the adapter set.
