Plan on giving Chris a hand on sunday changing out his new shafts.. After replacing the seals on my front 44 its a pain if the seal gets moved during axle setup.. I noticed on the rubi forum that the new seal kit comes with white plastic spacers that keep the axle center in the housing when installing. Can these be bought anywhere?????
I guess the best plan would be to open the diff and try to get your hand in there and help center the axle when it comes through the seal.
Nester, you got plans for Sunday?? You being the axle specialist and all...
Nothing special needed for the rubi is there.. 36mm socket..
