| YJ clunk in front end found | |
| Subject: YJ clunk in front end found Thu Jul 10, 2008 3:43 pm | |
| Ok so I found that my steering box bolts were loose. no problem right. Actually found that they werent loose the nut that was pressed into the frame came out so both bolts could not be tightened up or loosened up. Cut them off and now going to drop a couple bolts into the frame and put a couple nuts on the bottom side. Going to weld the bolts in there to keep them from turning. | |
| Subject: Re: YJ clunk in front end found Thu Jul 10, 2008 8:37 pm | |
| Tell ya what. its a good thing I didn't go wheeling on sunday at big dogs because the way the frame was cracked and the two lower bolts being loose the steering box could have very well ripped off the frame. it is fixed now. Dropped two larger 9/16 bolts down through the frame and welded them in there. Then bolted the steering box mount to them. welded the cracked area of the frame and reinforced with some steel plate. She is ready to roll again. | |
| Subject: Re: YJ clunk in front end found Fri Jul 11, 2008 10:33 am | |
- She is ready to roll again.
well hopefully not literally | |
| Subject: Re: YJ clunk in front end found Fri Jul 11, 2008 1:46 pm | |
| there's a first time for everyone. | |
| Subject: Re: YJ clunk in front end found Fri Jul 11, 2008 10:05 pm | |
| let me know when you have some free time in aug to make run at RC. | |
| Subject: Re: YJ clunk in front end found Fri Jul 11, 2008 10:30 pm | |
| August 9, 10 and aug 30-31(labor day weekend) I can do it. 1st weekend going to Ocean City to visit my mom, 3rd weekend I'm busy, and the 24th is the local mud bog. | |
| Subject: Re: YJ clunk in front end found Sat Jul 12, 2008 8:13 am | |
| 9th and 10th may work. I'll let you know when the time gets a little closer. | |
| Subject: Re: YJ clunk in front end found Sat Jul 12, 2008 9:52 am | |
| Cool, I blocked it off on my calander. | |
| Subject: Re: YJ clunk in front end found | |
