 Front diff leak and service front end
Front diff leak and service front end Empty
PostSubject: Front diff leak and service front end   Front diff leak and service front end Icon_minitimeSun Dec 14, 2008 10:46 pm
I tore the whole front axle down just to repair a leaking front diff on the 609 axle. During the disassembly found that the bearings needed repacked anyway, I usually do that once a year. On the passenger side The warn hub drive flange fell out in about 6 pieces when I took the little screw out. Also found the diff fluid was in desperate need of changing, not as water tight as I believed. So time to order a new warn hub. I decided to switch to drive flanges instead of manual hubs for added strength. I really don't drive it on the road and I have an ARB in the front anyway so no big deal. After reading the BillVista review on drive flanges I ordered the polyperformance drive gear kit.
Front diff leak and service front end D_4951-01
PostSubject: Re: Front diff leak and service front end   Front diff leak and service front end Icon_minitimeSun Dec 14, 2008 10:47 pm
Oh yeah my front driveshaft is nearly seized up so time to lube that up and see if I can free it up.
jealos-z
jealos-z
Number of posts : 604
Emploi : Mechanic
Registration date : 2007-09-17
PostSubject: Re: Front diff leak and service front end   Front diff leak and service front end Icon_minitimeMon Dec 15, 2008 11:17 pm
Those flanges look sweet....
PostSubject: Re: Front diff leak and service front end   Front diff leak and service front end Icon_minitimeMon Dec 15, 2008 11:42 pm
x2 good move in my opinion
PostSubject: Re: Front diff leak and service front end   Front diff leak and service front end Icon_minitimeTue Dec 16, 2008 12:04 am
I read that the warn manual hubs have a lifetime warranty so I'm turning it in for a replacement and then will probably sell the set.
jealos-z
jealos-z
Emploi : Mechanic
PostSubject: Re: Front diff leak and service front end   Front diff leak and service front end Icon_minitimeTue Dec 16, 2008 9:02 pm
Drive Flanges are the way to go I have broke a hub the last 3 times out thank god for warranty, I am putn flanges on from now on when I wheel.
PostSubject: Re: Front diff leak and service front end   Front diff leak and service front end Icon_minitimeSun Dec 21, 2008 1:39 am
Front axle has been assembled. I did swipe the drive flanges off the CJ to finish the YJ. Spend about an hour freeing up the front driveshaft that had seized up. Now it is super slippery and telescopes well. Finally the jeep is off of the jackstands. I tested the arb and found it was leaking air somehwere. Traced it down to a busted nut where the tube enters the front housing, luckily I had a spare and now all is good. I still need to fix the steering fitting and install bump stops.
» Front End Work
» disconnecting front sway bar
» i like this front clip
» YJ clunk in front end found
» Cherokee front axle??
