| disconnecting front sway bar | |
s-n-o-w Open/Locker
Number of posts : 40 Age : 33 Localisation : Parkville(Baltimore) Registration date : 2007-10-27
| Subject: disconnecting front sway bar Mon Nov 12, 2007 9:40 pm | |
| During the lift I found that it was rusted and once it was lowered to the ground it broke and is now off.
is there a big problem with this or should I be good for a little while? | |
| Subject: Re: disconnecting front sway bar Mon Nov 12, 2007 9:57 pm | |
| I ran without a front sway bar for a couple of years. but I had skyjacker springs which are very stiff. I now have rubicon express springs and I wouldn't even think about going sway bar less on the road. | |
| Subject: Re: disconnecting front sway bar Mon Nov 12, 2007 10:26 pm | |
| Hey dude your cool for know. Your springs are new and fresh but I would put a set a Disconects high on your list. Just be easy on turns and learn your jeeps limits and when you can buy some discos. Just dont put it off. | |
s-n-o-w Open/Locker
| Subject: Re: disconnecting front sway bar Mon Nov 12, 2007 11:38 pm | |
| thanks for the help.
http://www.suspensionconnection.com/cgi-bin/suscon/41806GC.html
good brand or no? if it checks out with you guys I will order them now. | |
| Subject: Re: disconnecting front sway bar Tue Nov 13, 2007 12:03 am | |
| On the cheap those will work. I would say get those and your set for awhile till you go over 4 or 5 inches of lift. | |
s-n-o-w Open/Locker
| Subject: Re: disconnecting front sway bar Tue Nov 13, 2007 8:42 am | |
| yeah, may go higher next year. thanks for all the help | |
timberwolf LS/Locker
Number of posts : 62 Age : 52 Localisation : Parkville, Md Registration date : 2007-11-02
| Subject: Re: disconnecting front sway bar Tue Nov 13, 2007 11:19 am | |
| - s-n-o-w wrote:
- thanks for the help.
good brand or no? if it checks out with you guys I will order them now. if you plan on going higher, i would recommend a set of beefier & adjustable JKS disco's. had them on my old ZJ worked great. plus, when i added more lift, i just adjusted the length. http://www.quadratec.com/products/16160_01.htm those are for up to 4 inches lift, but you can get longer like i had with 7 inches lift. if ya go this route, shop around. sometimes you can get a better than Quadratec price. | |
s-n-o-w Open/Locker
| Subject: Re: disconnecting front sway bar Tue Nov 13, 2007 9:09 pm | |
| nice, I am looking at some of there armor to | |
| Subject: Re: disconnecting front sway bar | |
