| DEATH SHAKE!!! | |
+4Rockn93YJ md4wheelin connordanny clark687 8 posters |
clark687 Locker/Locker
Number of posts : 120 Age : 34 Localisation : Bel Air, Maryland Emploi : CNC Machinist Registration date : 2008-08-13
| Subject: DEATH SHAKE!!! Wed Sep 03, 2008 10:31 pm | |
| i have a shake. known as death shake. in the front when i go up a hill or i would turn, if i hit a bump it will be such a bad shake i have to slow down. i thought that it would be the shock in the middle of the two front tires. i have no idea what it is called. but hears my little drawing..
0--==--0 the equal sign around that area.
hey since when was there spell check, what a help full tool on here | |
| Subject: Re: DEATH SHAKE!!! Wed Sep 03, 2008 10:54 pm | |
| Did you get an alignment done after your lift went on? That could be all you need. The shock thing is your steering stabilizer, but that shouldn't be causing any death shake. | |
| Subject: Re: DEATH SHAKE!!! Thu Sep 04, 2008 12:17 am | |
| its actually called the death wobble, but get an alignment done and see if this helps. | |
| Subject: Re: DEATH SHAKE!!! Thu Sep 04, 2008 8:18 am | |
| Agreed, steering stabilizer wont cause death wobble but it can help reduce it. Alignment should be your first move. If you still have the death wobble then you likely have something loose in the front suspension or steering system. | |
| Subject: hey Thu Sep 04, 2008 5:20 pm | |
| alrite no i havent but i need to wheres a good place togo | |
| Subject: Re: DEATH SHAKE!!! Thu Sep 04, 2008 9:35 pm | |
| NTB or any of the tire places can do it pretty quick. | |
| Subject: Re: DEATH SHAKE!!! Thu Sep 04, 2008 9:58 pm | |
| I hear sears in whitemarsh has someone there that knows a little about jeeps | |
| Subject: Re: DEATH SHAKE!!! Sat Sep 06, 2008 1:26 pm | |
| air pressure too... 35 psi is recommended for your stock size... 30"... i run my 33s around 22 to 26 psi... it does not totally cure the wobble, but it allows a softer tire to help cushion some of it... bigger tires at same psi to smaller tires act as stiffer shocks... they are designed for heavier working load... alignment, then double check wheel balance, then maybe lower psi 2 or 3 pounds at a time... it won't totally go away, even stock jeeps can get it... but as long as you are aware of the zone and careful it won't be a problem... its a lifted jeep thing... | |
| Subject: Re: DEATH SHAKE!!! Sat Sep 06, 2008 1:43 pm | |
| I don't have any death wobble. A little bump steer, but my stock ford has more bump steer than the jeep. | |
| Subject: Re: DEATH SHAKE!!! Sat Sep 06, 2008 7:13 pm | |
- I hear sears in whitemarsh has someone there that knows a little about jeeps
Dam, can i get his name and number. Maybe he can fix my beat up jeep...... | |
| Subject: Re: DEATH SHAKE!!! Sun Sep 07, 2008 8:05 am | |
| Merchants tire in Bel Air for a little more gives you up to a 3 year warranty that you can bring it back as many times as you want for that period for free.
Got it done there for my Dodge but not yet for the Jeep. | |
| Subject: Re: DEATH SHAKE!!! Sun Sep 07, 2008 8:06 am | |
| PS, every time I have had death wobble it was related to the front track bar. Check that next. | |
| Subject: Re: DEATH SHAKE!!! Sun Sep 07, 2008 11:29 am | |
| - Chris Taylor wrote:
- Merchants tire in Bel Air for a little more gives you up to a 3 year warranty that you can bring it back as many times as you want for that period for free.
Got it done there for my Dodge but not yet for the Jeep. Guess they get their parts guys to warranty trail broken parts too....... | |
| Subject: Re: DEATH SHAKE!!! Sun Sep 07, 2008 12:13 pm | |
| but when my parts guy gives me a hand.. I can get it re aligned for free.
I guess this would be a bad time to tell you I bent the drag link again huh? | |
| Subject: Re: DEATH SHAKE!!! Sun Sep 07, 2008 1:49 pm | |
| - UPNOVER wrote:
Dam, can i get his name and number. Maybe he can fix my beat up jeep...... I didn't say he knew that much | |
| Subject: Re: DEATH SHAKE!!! Sun Sep 07, 2008 5:21 pm | |
| Subject: Re: DEATH SHAKE!!! | |
| DEATH SHAKE!!! | |
