| Subject: Good 14 bolt tech.. Fri Nov 21, 2008 11:52 am | |
| some nice 14 bolt work
http://pirate4x4.com/forum/showthread.php?t=734772 | |
| Subject: Re: Good 14 bolt tech.. Fri Nov 21, 2008 1:54 pm | |
| I have been wanted to do that for a while, but a guy I know that does machineing couldn't figure out how mount the ring gear on the lathe with out making an adapter which would take to much time in itself. One of these days I will just take a grinder to it. | |
| Subject: Re: Good 14 bolt tech.. Fri Nov 21, 2008 7:53 pm | |
| I posted this for you... I think you should go ahead and tackle it.. I'll come help as long as you make the first cut...lol | |
| Subject: Re: Good 14 bolt tech.. Fri Nov 21, 2008 8:16 pm | |
| just open the cover, put the rear on jack stands, start the vehicle and put it in 1st gear low and let it idle the rear slowly. wahlah instant lathe and you can grind away. | |
| Subject: Re: Good 14 bolt tech.. Fri Nov 21, 2008 11:24 pm | |
- just open the cover, put the rear on jack stands, start the vehicle and put it in 1st gear low and let it idle the rear slowly. wahlah instant lathe and you can grind away.
My dad has a big ass commerical belt sander made by craftsman years ago.. It would be alot easier than a grinder and smoother at that. | |
| Subject: Re: Good 14 bolt tech.. Sat Nov 22, 2008 11:52 am | |
| I don't know if I'd want a commercial sander taken to my rear. | |
| Subject: Re: Good 14 bolt tech.. | |
