| valve stem replacement | |
+5jealos-z makitupthehardway thinga'ma'rig Rockn93YJ connordanny 9 posters |
| Subject: valve stem replacement Tue Jul 14, 2009 1:36 pm | |
| I have a leaking valve stem on the TJ and plan on replacing it tonight. Do I just rip the old one out with the vice grips, lube up the new one and jam it in the hole? Or should I break the bead, pull it out from the inside of the wheel and press the new one in? Never had to mess with one before. Thx | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 2:20 pm | |
| I believe you need to break the tire from the wheel and insert it from the inside. All the ones I've ever installed took a nut on the inside of the rim. | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 2:27 pm | |
| you are going to have to break the bead, you can come over to the shop and use my machine to do it if you like to. | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 4:14 pm | |
| thanks guys.
I'll try it at home first Von - you know with the hi-lift and ratchet strap | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 4:43 pm | |
| - connordanny wrote:
- thanks guys.
I'll try it at home first Von - you know with the hi-lift and ratchet strap Sorry Danny but that sounds like alot of work when you can get a flat repair at a local shop done for 20 bucks plus the valve stem. I would throw that sucker in the bed of the truck and drop it off on the way to work and pick it up on the way home. But if you do the hilift and strap find someone to video it cause I have never seen it done that way. | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 5:09 pm | |
| I wood drive on bead with truck them reach in and change valve stem you only have to break one side of bead them air it back up | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 5:20 pm | |
| Yeah but they dont always come off that easy unless you have a heavy truck. | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 5:47 pm | |
| - jealos-z wrote:
- I wood drive on bead with truck them reach in and change valve stem you only have to break one side of bead them air it back up
x2 - I've done them this way before | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 6:12 pm | |
| I have used the hi lift many times. if you use a pair of dykes and cut the back of the valve stem it will come out easier. I wouldn't pay $20 to do it. its like a 5 min job | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 7:42 pm | |
| Danny I have a tool that will break the bead at the house if you want to bring it over here HF tool got to love this place | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 9:07 pm | |
or take a skid steer bucket and push down on it | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 9:56 pm | |
| Backhoe works too | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 10:31 pm | |
| I used the highlift and it worked out right away. Matt - thanks for the tip about cutting the bastard. I prolly woulda been tuggin on it all day long I put the new stem in, then cranked up the compressor and the bead set itself. It was pretty easy | |
| Subject: Re: valve stem replacement Tue Jul 14, 2009 10:32 pm | |
| Joe - I'll save the skid steer for heavy duty jobs like crushing a 6 pack | |
| Subject: Re: valve stem replacement | |
