| | Brake line replacement HELP! | |
| Author | Message |
chics4jeeps Locker/Locker
 Number of posts: 119 Age: 41 Localisation: North East, MD Registration date: 2007-01-22
 | Subject: Brake line replacement HELP! Mon May 05, 2008 12:48 pm | |
| We have been noticing a slight leak on the passenger side front brake line. Where the line meets the hose. We have also discovered a leak further up the line as well. After a very slight turn of the flare nut wrench, the brake line crumbled into a rusty mess at the connection. Our question is: how hard is it to replace the front brake lines on the 1983 CJ7??  |
natedogg_66 LS/Locker
 Number of posts: 74 Age: 31 Localisation: Dundalk Registration date: 2008-02-17
 | Subject: Re: Brake line replacement HELP! Mon May 05, 2008 3:43 pm | |
| which brake lines the flex lines or hard lines attached to the frame??? |
 Number of posts: 2550 Age: 30 Localisation: Ashburn, VA Registration date: 2007-01-19
 | Subject: Re: Brake line replacement HELP! Mon May 05, 2008 5:39 pm | |
| Not hard at all you will need all the tools for cutting and fitting brake lines and can of PB blaster and time. You will need to buy a couple of lines so you can practice but its not hard its just time consuming and boring work. I will suggest doing all the hard brake lines that look bad and getting a set of new extended steel braded lines. It won't go to waste since most life kits dont include brake lines. _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 Number of posts: 438 Age: 58 Localisation: Parkville, Maryland Registration date: 2007-01-19
 | Subject: Re: Brake line replacement HELP! Mon May 05, 2008 7:33 pm | |
| you can buy all prebent line that are an extact fit but they cost the most. the hardest part it getting the old stuff apart. Welcome to the CJ world  |
 | Subject: Re: Brake line replacement HELP! Mon May 05, 2008 11:01 pm | |
| | natedogg_66 wrote: | | which brake lines the flex lines or hard lines attached to the frame??? |
It's the hard lines coming from master cylinder to frame. Also, it does have longer SS hoses from PO. While I'm doing all this I want to put in a YJ booster & mc...any tips on that?
Thanks for the welcome Paul...I'll remember to call you when I'm getting my ass kicked by this thing  |
 Number of posts: 146 Age: 24 Localisation: Odenton, Md Registration date: 2007-01-20
 | Subject: Re: Brake line replacement HELP! Mon May 05, 2008 11:33 pm | |
| get one from a 95 it has the dual diapraghm booster and master cylinder vs the 94 and before single |
CamoK5 Locker/Locker
 Number of posts: 153 Age: 46 Localisation: Havre de Grace, MD Registration date: 2007-01-20
 | Subject: Re: Brake line replacement HELP! Tue May 06, 2008 5:52 am | |
| Go here for prebent lines.
http://www.rightstuffdetailing.com/2004_pdf/jeep.pdf |
 Number of posts: 1873 Age: 33 Localisation: Towson, MD Registration date: 2007-01-20
 | Subject: Re: Brake line replacement HELP! Tue May 06, 2008 12:26 pm | |
| the only brake line flaring kit that I found that works 100% is the snap on kit. the ones that you get at the auto store are junk. Also if you want to stop on a dime, go with a E350 MC and booster. _________________ "A yahoo made dangerous with power tools"  MARR step up or step out Who me? I didn't do it and you can't prove it. Also by chance do you have a lighter? |
 | Subject: Re: Brake line replacement HELP! Wed May 07, 2008 10:06 am | |
| Ok these are going to be dumb questions so bear with me please...I'm doing all the work myself and brake lines are a first..
If I choose prebent lines will the fittings fit an upgraded MC & booster and proportioning valve? On that note...I see that prebent come for power or standard disc brakes...can I assume with the booster it will now be power brakes? And what difference does power or without make when ordering...fittings, line strength??
If I go with bending my own...what kind and diameter? Quadratec has tubing kits but in 3/16", 1/4", etc.
Since I'm a virgin at the brake thing...what MC replacement will get me the best stopping power with the least mods?...I'm hearing 95 yj or the one from the Ford. |
 | Subject: Re: Brake line replacement HELP! Wed May 07, 2008 10:25 am | |
| YJ Master in CJ http://www.jeepsunlimited.com/mambo2/index.php?option=com_content&task=view&id=42&Itemid=30
Apparently you can get a gm master and it will bolt up to a cj "With a CJ the solution is to go to a GM master cylinder from a vehicle with 4 wheel discs (usually a 79 Pontiac Firebird) " from http://www.4x4wire.com/jeep/tech/brakes/yjmc/ |
 | Subject: Re: Brake line replacement HELP! Wed May 07, 2008 8:02 pm | |
| here is the same write up that sonofsam02 gave you but more detail write by the same guy. http://www.bustedjeep.com/projects/yjbrakes.asp
Bustedjeep.com has some good write ups I have meet this guys and they have build some great CJs.
I went this route http://cgi.ebay.com/ebaymotors/1974-1986-JEEP-CJ-SERIES-POWER-BRAKE-BOOSTER-ASSEMBLY_W0QQcmdZViewItemQQcategoryZ33566QQihZ001QQitemZ110250406849QQrdZ1QQsspagenameZWDVW
This guy will help you out if you have a problem he knows brakes inside out and upside down. He will talk you through any problem even if you did not buy anything from him. Great Guy http://www.vancopbs.com/
Good luck these things take some time but it worth it. |
 | Subject: Re: Brake line replacement HELP! Fri May 09, 2008 12:29 pm | |
| Awesome...thanks everyone for all the info...  |
 | Subject: Re: Brake line replacement HELP! Wed May 14, 2008 12:09 pm | |
| Checking into my local pick & pulls for brake booster & mc from 95 YJ to go on the CJ. Getting asked if I need it to come from a 4 or 6 cyl. Does it matter what engine it comes from? I've done the searchs and can't find the answer. |
 | Subject: Re: Brake line replacement HELP! Thu May 15, 2008 9:21 am | |
| Autozone says: that it needs to come from a six cylinder. Its the master cylinder with the plastic resivoir on top instead of a metal one |
