| Problem with my dodge | |
THE ROOKIE LS/Locker
Number of posts : 78 Age : 37 Registration date : 2009-08-10
| Subject: Problem with my dodge Tue Aug 25, 2009 1:31 pm | |
| Subject: Re: Problem with my dodge Tue Aug 25, 2009 2:00 pm | |
| Looks like somebody spilled their Kool-Aid! Is it ATF coming out of the tcase? | |
MonsterS10 Locker/Spool
| Subject: Re: Problem with my dodge Tue Aug 25, 2009 2:53 pm | |
| 90% of the aluminum t cases use trans fluid looks like the output seal is leaking common problem | |
| Subject: Re: Problem with my dodge Tue Aug 25, 2009 6:17 pm | |
| X2 exspecialy with a slip yoke | |
| Subject: Re: Problem with my dodge Tue Aug 25, 2009 6:22 pm | |
| http://www.pirate4x4.com/forum/showthread.php?t=756974 | |
| Subject: Re: Problem with my dodge Tue Aug 25, 2009 7:48 pm | |
| - connordanny wrote:
- Looks like somebody spilled their Kool-Aid!
Is it ATF coming out of the tcase? - MonsterS10 wrote:
- 90% of the aluminum t cases use trans fluid looks like the output seal is leaking common problem
Nope, not Kool-Aid... Didnt taste that great I looked around the tcase and couldnt see where it would be coming out of so I'm still dumbfounded | |
| Subject: Re: Problem with my dodge Tue Aug 25, 2009 8:52 pm | |
| Looks like this thats were it will be leaking. | |
| Subject: Re: Problem with my dodge Tue Aug 25, 2009 8:56 pm | |
| Ill look at it first thing tomorrow after work. But I'm pretty sure it was dry.
But even with something a small as that, I'm goin to try and drive 9-10hrs to pick up a yota, I should have no problems with that right? | |
| Subject: Re: Problem with my dodge Tue Aug 25, 2009 9:11 pm | |
| I wouldnt drive 10 min with a leak like that but thats jus me.. If t case runs dry u r done | |
| Subject: Re: Problem with my dodge Wed Aug 26, 2009 11:54 am | |
| Subject: Re: Problem with my dodge Wed Aug 26, 2009 11:55 am | |
| Also thanks for the help guys, I really appreciate it. | |
| Subject: Re: Problem with my dodge Wed Aug 26, 2009 2:01 pm | |
| It does look like a new seal - rockdw72 wrote:
- http://www.pirate4x4.com/forum/showthread.php?t=756974
see link all you need is a wrench to take the drive shaft off at the axle then just pull the yoke out of the t-case. Then tap the seal out with a hammer and a flat head. install new seal carefully with a block of wood and a hammer, re-install drive shaft. You can rent special tools from most auto parts stores and it doesn't cost anything. Put money down then get it back when you return the tools. only space you need to work on it is under the truck. | |
| Subject: Re: Problem with my dodge | |
