| Kims Buggy Build @ R & S Auto and Custom Fab | |
+10Eskimo thinga'ma'rig Hunt Locked_N_Loaded MonsterS10 rockdw72 makitupthehardway md4wheelin Rockn93YJ SPP YJ 14 posters |
| Subject: Kims Buggy Build @ R & S Auto and Custom Fab Tue Feb 02, 2010 10:49 pm | |
| Thought it was about time to let everyone know whats been going on at R & S.
As some of you know R & S is building Kim a rock racer / trail buggy and its coming along good. Chris and I have been putting in some time on the build and thought it was time to post some progress pics. I really like the way its coming out Kim you should have a very nice rig when complete, get ready to go fast. Here are some pics I took with my cell phone I will take my camera down and get some more and keep things up to date from here on out.
http://picasaweb.google.com/toyota327/KimsBuggyBuild# | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Tue Feb 02, 2010 11:22 pm | |
| Damn that tube looks good! | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Tue Feb 02, 2010 11:39 pm | |
| - SPP YJ wrote:
- Thought it was about time to let everyone know whats been going on at R & S.
besides making pink rims | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Wed Feb 03, 2010 12:05 am | |
| I want a buggy so bad. One day...
Nice work Chris. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Wed Feb 03, 2010 2:00 am | |
MonsterS10 Locker/Spool
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Wed Feb 03, 2010 9:20 am | |
| thanks guys and chuck for posting picks i'm to computer stupid to do it myself . Chuck has as many hours in it as i do | |
Hunt Locker/Locker
Number of posts : 121 Age : 41 Registration date : 2009-04-05
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Thu Feb 04, 2010 7:03 pm | |
| Where are all the details? So what did the build spec turn out to be? Engine, tranny. t-case, shock, axles/components, etc. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Fri Feb 05, 2010 11:33 am | |
| - Hunt wrote:
- Where are all the details?
So what did the build spec turn out to be? Engine, tranny. t-case, shock, axles/components, etc. x2!!!!! | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Fri Feb 05, 2010 5:08 pm | |
| Well so far 1 5/8 tubing 5.7L LT1 350 Th350 trans with manual valve body atlas transfer case Dana 60 front Dana 70 rear full hydro steering alum 4 link front and rear
Coil overs(foa?) , wheels(17") , tires(40") ,lockers(ARB?) , rear work and gears,etc... still to come.
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Fri Feb 05, 2010 10:30 pm | |
| I think koh rules say 1 3/4 tube for main tube. Is there a rule for RCrocs. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Sat Feb 06, 2010 12:11 am | |
| From what i see that is a guide line not a rule. I Need to look at it a little closer. But if you read the rules post on pirate that rule started a lot of problems and it was said that was not the rule but a guide line.
here are the rules 19.2 is the cage rule and it says minimum mild steel tubing guideline
http://www.kingofthehammers.com/rulebook.php
let me know how you all take that after you read this
http://www.pirate4x4.com/forum/showthread.php?t=803536
post 12,15,17,23,24 etc... | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Sat Mar 13, 2010 12:14 pm | |
Pics are updated...
Well its going along good when the parts are here. As of now... The skins are about done The four link is done Seats brackets are done Transfer case is in and mount is made Radiator is mounted Hood is made (with its own cage !) Its sitting on a set of rollers till the wheels and tires show up then on to mounting the coil overs. Waiting for winch to show up to finish up the front. PSC full hydro steering is on its way. This week on to fuel cell, battery box, floor pans ,skids ,etc...
Will not be long till you see pics of this out on the trail but theres a little ways to go if the parts keep coming. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Sat Mar 13, 2010 4:35 pm | |
| i can't wait to see what kim does with that in the trails.... nice | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Sat Mar 13, 2010 5:48 pm | |
| looks like its going to be tall. Is air flow going to be an issue to the radiator. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Sat Mar 13, 2010 7:55 pm | |
- looks like its going to be tall. Is air flow going to be an issue to the radiator.
It is a little tall and wide for a buggy but we had to keep in mind the rules and what Kim wanted out of this build. There is a head room rule and with kim's height the seat needs to be up enough for her to be able to see over that V-8. from what I measured it should be a couple inches shorter than my YJ when its at ride height with the tires on it. As far as the grill it has a little more air flow than a factory jeep grill and also a hood scoop to help get ride of some heat. We needed to keep in mind Kim did not want to bump elbows with the person next to her, and also this is a multi purpose buggy not just a racer that is a hard thing to bring all day trail rig and race rig together in to one and make both easy and with comfort. As most people have found out a strictly racing buggy is not the most roomy and comfortable rig. I hope we have blended the two together into a rig Kim will be happy with no matter what she is doing. It will be a fun rig to run that is for sure. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Sat Mar 13, 2010 8:35 pm | |
| hard to tell from the pictures and I am not trying to nit pick. but is the roof screwed in with self tapers into the tube. I always thought that holes in the tube is a big no no. | |
Eskimo LS/Locker
Number of posts : 76 Age : 49 Localisation : Danville, PA Registration date : 2009-10-20
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Sun Mar 14, 2010 12:16 pm | |
| Mine held up ok with holes for pop-rivets for the roof... By the way, if you haven't thought about it, a long string or 10 of clear sillycone between the roof and the tubing goes a LONG way to quell buzzing and rattles.. Wide buggies rule! | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Sun Mar 14, 2010 10:15 pm | |
| Checked on the hole drill thing it is not a proplem. Only WEROCK has a proplem with this . RCROCS and KOH says no proplem. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Mon Mar 15, 2010 12:50 pm | |
| Are you saying that someone said it was ok or there is not a written rule agaist it. It would suck to do all that work and not pass tech | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Mon Mar 15, 2010 1:47 pm | |
| No written rule i have the rules in front of me it does not weaken the tubing sheet metal has been being riveted to tubing for as long as i know in just about every form of racing | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Mon Mar 22, 2010 11:46 pm | |
| what thickness sheet metal are you using for firewalls? rules do not clearly specify. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Tue Mar 23, 2010 8:18 am | |
| Chuck talked to the guy in charge of tech inspection 18 gauge steel they are thinking about getting rid of aluminum because of the fires at koh the rear is 1/8 alum. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab Tue Mar 23, 2010 9:13 am | |
| thanks, good to know. I agree with gettting rid of the alum for firewalls, stuff melted away like nothing was even there. I have to pick up some alum today so I'll get some 18 gauge sheet metal while I'm there. | |
| Subject: Re: Kims Buggy Build @ R & S Auto and Custom Fab | |
