 lift kit on my yj
killerisdead
Open/Locker
Open/Locker
killerisdead
Number of posts : 37
Registration date : 2007-04-30
lift kit on my yj Empty
PostSubject: lift kit on my yj   lift kit on my yj Icon_minitimeTue May 15, 2007 10:05 am
alright i started the lift project last night .all was going well untill it came to getting the bolt out of the leaf spring at the frame side it seem to be rusted in the sleave that in the middle of that bushing and i cant get it out ive tried every thing i can think of short of cuting it out .any suggestion would be nice and does any one know what size that bolt is and were i might be able to find anuther ive looked in all my catalogs and online and all i can find is the hanger but no bolt .thanks...........cameron chainsaw saw2
PostSubject: Re: lift kit on my yj   lift kit on my yj Icon_minitimeTue May 15, 2007 12:45 pm
I had the same problem with my YJ when it had leaf springs. the bolt is most likely rusted into the sleeve and no there is no real way of getting it out with conservative means. In other words you will be trashing the bolt to remove it. I first cut off the head of the bolt with a sanding disk and then tried to pound it through towards the nut side using a very large hammer and punch without success and ended up cutting the bolt again inside the bracket on both sides to get it removed. I may have even cut the leaf spring itself to remove the bolt since I wasn't going to use the spring again. good luck. by the way if you don't have a grinder with cutting discs this would be a good time to invest in one...and a face shield.
PostSubject: Re: lift kit on my yj   lift kit on my yj Icon_minitimeTue May 15, 2007 3:09 pm
Hey Camron
Here is how I do it. There are a couple things you can try as far as getting it out. I have used a torch a couple of times and that did the trick quick and easy. Other times I have gone to the store and pick up a can of sea foam bolt remover or PB blaster. If all that doesn't work thats when I pull out the sawzall chainsaw A good metal blade and some wd-40. Normally just cut right between the spring and the mount. If your clean and good with the saw you won't mess up the bushing. If you lift kit came with new bushings then dont worry about it and go to town on it Twisted Evil As far as where you get the bolts to replace them with I use grade 8 bolts you get at Lowes or Home Depot. There nice cause there zinc plated and dont rust. Go Idea to just change all the stock bolts while your at it. Its so nice to have leaf sprung rigs in this club.
killerisdead
Open/Locker
Open/Locker
killerisdead
PostSubject: yj lift   lift kit on my yj Icon_minitimeWed May 16, 2007 1:33 pm
yeah rock on cut that bolt out last night and order some new ones from the dealer so now its onward and upwards thanks.............cameron lk
killerisdead
Open/Locker
Open/Locker
killerisdead
PostSubject: its done   lift kit on my yj Icon_minitimeSat May 19, 2007 7:06 pm
this thing is awsome its like driving a little monster truck. hahahahahha now im going to drive over cars in traffic. hey if they didnt want my tire on them they would have bought a bigger car........cameron
PostSubject: Re: lift kit on my yj   lift kit on my yj Icon_minitimeMon May 21, 2007 12:11 am
how much lift and what size tires did you get?
killerisdead
Open/Locker
Open/Locker
killerisdead
PostSubject: lift   lift kit on my yj Icon_minitimeMon May 21, 2007 12:41 am
4 in rubicon express and 33s in reality i think i would need 35s at least to drive over a car in traffic . they sure made my ride today more fun so it was all worth it............cameron
lift kit on my yj
» To lift or not to lift that is the question?
» YJ LIFT
» New Hi-Lift Product
» New lift
» Lift questions
