| Author | Message |
 Number of posts: 438 Age: 58 Localisation: Parkville, Maryland Registration date: 2007-01-19
 | Subject: Axle Swap Sat Jun 02, 2007 10:43 am | |
| Getting started how long will ti take me ? Phase 1 remove old axle !!!!!!!   will update with pictures as it goes along hopefully not to long goal is ready for PA jeep show. |
 Number of posts: 1239 Age: 29 Localisation: north harford Registration date: 2007-01-20
 | Subject: Re: Axle Swap Sat Jun 02, 2007 2:04 pm | |
| got to love HF jack stands. I am using the same ones right now. Why is every one doing major mods in peak wheeling season.  damn fools |
 Number of posts: 2550 Age: 30 Localisation: Ashburn, VA Registration date: 2007-01-19
 | Subject: Re: Axle Swap Sat Jun 02, 2007 10:25 pm | |
| With any luck I will be done in a week or two  Its looking good Paul you got Toyota axles right? _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 | Subject: Re: Axle Swap Sun Jun 03, 2007 7:56 am | |
| | makitupthehardway wrote: | With any luck I will be done in a week or two Its looking good Paul you got Toyota axles right? |
That's great that you'll almost done. Yes I'm using Toyota axles. Working on the sping hangers now need to move springs out 3/4" |
 | Subject: Re: Axle Swap Sun Jun 03, 2007 6:44 pm | |
| can't wait to see it done. you don't see to many jeeps with toy axles |
 | Subject: Re: Axle Swap Wed Jun 13, 2007 5:11 pm | |
| Axles will be locked both front and rear can't wait to get this done  |
 | Subject: Re: Axle Swap Wed Jun 20, 2007 8:01 pm | |
 | Subject: Re: Axle Swap Wed Jun 20, 2007 8:23 pm | |
| looking good Paul I didn't think that you were doing that much work but looking at the housing you kinda don't have any way to get around it. Are you going to move the springs around in the rear at all? It would be a good time to extend the wheel base.  _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 | Subject: Re: Axle Swap Wed Jun 20, 2007 9:34 pm | |
|  looks good |
 | Subject: Re: Axle Swap Thu Jun 21, 2007 7:44 pm | |
| | makitupthehardway wrote: | Are you going to move the springs around in the rear at all? It would be a good time to extend the wheel base.  |
No moving of the rear springs just readjusting the spring preches. Still looking for things I need for Japan meets AMC. |
 | Subject: Re: Axle Swap Thu Jun 21, 2007 9:47 pm | |
| Paul what gears are you planning to run in the YOTA axles? Or are you waiting to get thru the build before you start building the axles? _________________ 94YJ Tera low 4:1, 4:10's, HP D44 front locked, 8.8 rear locked, 37" Truxus M/T's, custom spring over front/spring under rear, along with other stuff (Trail rig) 00WJ open/open, lifted 31" MTR's (curbcrawler) 84 Toyota Pickup open front, welded rear, 63" chevy rear springs, propane injection, 37" mtr's, 4.7:1 Tcase 07 FORD E350 SD (TOW VAN)
 | Subject: Re: Axle Swap Fri Jun 22, 2007 4:17 pm | |
| | makitupthehardway wrote: | | Paul what gears are you planning to run in the YOTA axles? Or are you waiting to get thru the build before you start building the axles? |
Nester Sticking with the stock Toyota 4:10 gears planning to stay with 33". I am building the axle putting in the aussie lockers and just order Bobby LongField 30 spline Chromoly axles today these have the breaking strength of a dana 60 axle check out the test here a link. http://www.toyotasuperaxles.com/images/torquetestgraph.jpg |
 | Subject: Re: Axle Swap Wed Jul 04, 2007 11:29 am | |
| got the LongField 30 spline Chromoly axles won't be braking these.  |
 Number of posts: 1306 Age: 56 Localisation: PERRY HALL MD 21128 Emploi: New Suzuki and Used Car Sales Registration date: 2007-01-19
 | Subject: Re: Axle Swap Wed Jul 04, 2007 1:40 pm | |
| Wow, Paul you've been really busy. Everything is looking great, but why didn't you do a spring over? |
 | Subject: Re: Axle Swap Wed Jul 04, 2007 3:36 pm | |
| | Devil Dog wrote: | | Wow, Paul you've been really busy. Everything is looking great, but why didn't you do a spring over? |
to much money to go spring over I would have to get new springs and fight the battle of alxe wrap. If I used my springs it would be wayto high and this Jeep tips enough now. I was not going to do the longfieds until I broke the stock axle but I realy don't want to pull it apart after the first trip. |
